Results 1 to 7 of 7
Thread: HyperLaunch issue
  1. #1
    GamesMaster
    azda's Avatar
    Join Date
    Mar 2011
    Yorkshire, UK
    Thanks
    2
    Default HyperLaunch issue
    I have an issue when HyperLaunch is set to true that keyboard input 'Q' does not work.
    I am using an x-arcade 2 player Joystick which utilises keyboard inputs and the letter Q is used as a button on the 2 player control panel.
    Whenever HyperLaunch is used for an EMU this button isnt recognised unless I turn HyperLaunch off.
    Hope this makes sense, any help would be appreciated.
    This is my AHK script, I was wondering if the issue is because q is wanted by HyperLaunch but then again so is S which works on my joystick. Im stumped!
    Code:
    ;                                 MAIN SETTINGS                                ;
    ;[UNIVERSAL HOTKEYS]            ;SEPERATE MULTIPLE KEYS WITH &(ampersand) up to 2 keys.
    exitScriptKey   = q & s         ;Secret hotkey(s) to exit script if needed
                                    ;Not to be confused with exit emulator keys
    exitEmulatorKey = ~1 & ~2           ;This key/key combo will close any emulators
                                    ;that do not have normal closing methods.
    toggleCursorKey = t             ;hotkey(s) to show or hide cursor if needed
                                    ;when hideCursor below is true
    ;[MOUSE CURSOR]
    hideCursor      = false         ;Automatically hide cursor during script
                                    ;WARNING: Make sure ALL your emu's are running fine
                                    ;before setting this to true as a precaution.*
    ;[WINDOWS]
    hideDesktop     = true          ;Attempts to hide desktop with black screen, might help
                                    ;on some emu's for hiding launching windows.
    hideTaskbar     = false         ;Hide the windows taskbar when running emu's.
                                    ;         before setting this to true as a precaution.*
    daemontools     = "C:\Program Files\DAEMON Tools Lite\daemon.exe"        ;Hide the windows taskbar when running emu's.
        *:If for some weird reason the script hangs follow these steps to get back to normal.
          1. If an emulator hangs up or cant load your game then first try to exit the emu
             by pressing your Emulator exit hotkey above.
          2. If your emu exited but your mouse cursor is gone use your cursor toggle hotkey.
          3. Next try to exit the script by pressing your Exit Script Hotkey above. This
             will also bring back your cursor and taskbar is they are set to true.
  2. #2
    Ultimate HyperSpin Guru
    Join Date
    Mar 2010
    portugal
    Thanks
    91
    Default
    Replace
    by
    exitScriptKey = ~q & ~s
    And see if it solves the problem.
  3. #3
    GamesMaster
    azda's Avatar
    Join Date
    Mar 2011
    Yorkshire, UK
    Thanks
    2
    Default
    Thanks Brolly ... that did the trick.
    Can you explain the issue please ... what does the '~' actually do?
  4. #4
    Not Even Remotely Dorky!
    chillinwater's Avatar
    Join Date
    Mar 2009
    Concord, Californee
    Thanks
    17
    Default
    "~" allows the keys to be used in other programs\emus while hyperlaunch is active.
    Without it the buttons can only be used in script only.
    Hyperlaunch Hijacks them and keeps them for itself.
    When you play 2 player games the Q & S buttons when pushed at the same time are going to kill Hyperlaunch which will have the effect of a "crash".
    So while its good to have "~" in front of your keys its better if you dont use Q & S or any other frequently used keys that are on the Xarcade.
    I use
    exitscriptkey= ~m & ~n
    toggglecursorkey= ~t
    but other keys will work too
  5. #5
    GamesMaster
    azda's Avatar
    Join Date
    Mar 2011
    Yorkshire, UK
    Thanks
    2
    Default
    Thanks for the info!
    I will ammend to the same as you as Q & S are very close to one another on the X-Arcade!
    Thanks again!
  6. #6
    HyperNewbie
    Join Date
    May 2011
    Oktoberfest
    Thanks
    Default
    Is it possible to use two different buttons for the "exitemulatorkey" funktion? (so or- instead and-funktion)
    I´ve tried a trick to use a key from controller 1 or a key from controller 2 but it doesn´t work:
    exitEmulatorKey = +
    Hotkey, $joy9, Exitemulator1
    Hotkey, $2joy9, Exitemulator2
    Exitemulator1:
    Send, {+}
    Return
    Exitemulator2:
    Send, {+}
    Return
  7. #7
    Join Date
    Mar 2009
    Concord, Californee
    Thanks
    17
    Default
    Somthing like this?:
    Hotkey, $2joy9, Exitemulator1
    Exitemulator1:
    Send, {+}
    Return
    and\or for "Exitemulator:"
    (should only need one of these lines below "Exitemulator:")
    Exitemulator1:
    process, close, %executable%
    process, close, "actual window name on the taskbar"
    winclose, %executable%
    winclose, "actual window name on the taskbar"
    send, {the}{keys}{that}{close}{the}{emulator} ;i.e. {lalt}{f4} or {esc}
    Return
Similar Threads
  1. NullDC hyperlaunch 2.0 issue
    By pinball2883 in forum HyperSpin Main Forum
    Last Post: 05-08-2013, 07:32 AM
  2. Hyperlaunch issue with PSXFIN
    By Rickysag in forum Emulator Setup / Settings
    Last Post: 09-18-2012, 05:38 AM
  3. HyperLaunch 2.X focus issue
    By rdhanded2 in forum HyperSpin HyperLaunch - AutoHotKey Scripting
    Last Post: 05-21-2012, 06:12 AM
  4. Strange hyperlaunch issue
    By j5350 in forum HyperSpin Support
    Last Post: 08-03-2009, 11:16 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
