Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 52
Thread: iPin3k - 46/32/19 LED Widebody
  1. #1
    Full Member Spuds's Avatar
    Join Date
    Aug 2011
    San Francisco, USA
    Thanks
    Default iPin3k - 46/32/19 LED Widebody
    Here we go again with another lurker deciding to build a cab. I'm totally not sure what I can contribute that is new to this hobby, since I am basically copying all the amazing cabs posted here. Anyway, I was starting to feel like a free-loader by consuming all the info here and not contributing. So here I go.
    I started building about 2 months ago. I call my simple cab "iPin3k" (looks like the word pink). I like iPin because of the apple brand of products. The 3k part is a homage to MST3k and the fact that I was hoping to only spend $3k on it (that went out the window about a week ago).
    This is a widebody build. I'm going to route the inside to fit the cab. Initial tests routing a piece of my 3/4" maple plywood indicates it is strong enough to hold at 1 1/2 ply remaining. I'll be bracing the crap out of everything because my goal is to allow the machine to be folded down and stoof up vertically for easy moving. We'll see how that goes.
    Following along with the boilerplate, here are the machine specs:
    PC
    - Intel core i5 3.1Ghz processor (over-clocked to 4.0)
    - Corsair HYDRO 100 water cooling kit (for over-clocking my CPU)
    - ASUS P8 Motherboard
    - 4GB RAM
    - NVidia GTX560 (for play field and backglass) / NVidia 8400 (for DMD)
    - 60GB Solid State Drive (for FAST table switching and loading)
    - TinyXP
    - SoundBlaster Creative Xtreme Audio card
    Here are the screens:
    - 46" Sharp LED (play field)
    - 32" LG LED (backglass)
    - 19" eMachine VGA (DMD)
    All my photos are in my Google+ account, but I'll post some of the more interesting ones here:
    The triumphant first test:
    Click image for larger version.
    Building the backbox:
    Mounting the screens:
    Testing, testing...
    A happy package arrives:
    Checking the widebody lockbar:
    More pics to come. I have now joined the ranks of the insane awesome.
    - Spuds
  2. #2
    gstav
    Guest
    Default
    Way to go spuds! Looks very professional!
  3. #3
    HyperSpin Guru Numiah's Avatar
    Join Date
    Aug 2010
    Netherlands
    Thanks
    1
    Default
    Welcome to the club Spuds !
    Your build is gonna rock !
    I think you're the first to use watercooling.
    **Each pinball machine is a tiny universe... that we control**
  4. #4
    look behind you... chriz99's Avatar
    Join Date
    Nov 2008
    Europe
    Thanks
    3
    Default
    awesome work so far! welcome on board!
    cheers
    chris
    46" visual pinball widebody * taito egret 29 candy cabs * indy & star wars pachinkos
  5. #5
    Join Date
    Aug 2011
    San Francisco, USA
    Thanks
    Default
    Thanks alot guys. Another reason I started this thread is because the amount of questions I have are exceeding my available time for reading through every build for the answer (and believe me, I've been reading them for MONTHS).
    My lack of woodworking skills has me stumped on a couple of issues. I have access to a SawStop table saw, a drill press, a hand router and a table router. But my questions are:
    1. What would be the best way to route the insides of my cab at a 6 degree angle? I'm not sure if I need to use the hand router or rig the table router to do it. If it were a straight angle route, it would be a no brainer, but I'd like the screen to be tilted toward the player at a pinball angle. I think chriz's build does that.
    2. What's an easy way to make the recessed holes for my buttons on the coin door? I have two round buttons (start and extra ball) and the rest are the rectangular buttons (from virtuapin).
    I've never messed around with woodshop tools before a month ago and can't find any info online to help with these. Duh.
    My MPT3k Pin Build
  6. #6
    P2K God ! mameman's Avatar
    Join Date
    May 2010
    Farmington Hills, MI
    Thanks
    2
    Default
    Quote Originally Posted by Spuds View Post
    best way to route the slot in the side is with a router running along a straight edge (aka 2x4). I think Chris used the same basic dimension I setup originally of 6degree's. this equates to basically 4" down at the back the screen from the top of the cab and 3/4" down at the front of the screen from the top of the cab.
    Square buttons, no idea....
    i assume you mean the front of the cab and not the actual coin door... for a round hole, you need to drill the outer hole first, i use a spade bit the size of the outer part of the button( 1 1/4") if i recall. once you have that drilled down far enough (around 3/8") so the button would be flush, you then drill the rest of the center out with a bit the size of the threaded section of the button (7/8") if i recall.
    looking good so far.
    CNC Work Here.....
  7. #7
    Join Date
    Aug 2011
    San Francisco, USA
    Thanks
    Default
    mameman, thanks for the tips. I swear, I can build fast PC's with ease, create web applications, I can even play the ukulele, but put a piece of wood in my hands and I'm completely lost.
    I'll be hand routing the inside cab with a straight edge. Also, I got the order of the button hole drilling wrong and your comment fixed my brain. It makes total sense.
    I'm a member of a local TechShop so all this equipment is available to me. But the guys who work there don't seem like they want to be bothered. Ah well. At least I got you guys. Hahahaha.
    My MPT3k Pin Build
  8. #8
    HyperNewbie dante's Avatar
    Join Date
    Jul 2011
    Raleigh, NC
    Thanks
    2
    Default
    I'm not a master woodworker, but here are some tips that I have picked up over the years
    1. As mameman stated, get a straightedge and clamp it to the cabinet to make a guide for the router. Try to go metal, mdf or plywood. If you go with real wood, you have to make sure it isn't warped. When clamping, go with several clamps - or just shortcut it and screw it down to ensure it doesn't move. Nothing is worse than routing and having the guide move on you.
    2. I personally like the Forstner Bits over the spade. They will leave a cleaner hole/flat bottom. Here's a link to what I'm talking about. Home Deopt/Lowes/Ace also sells them individually for roughly $5. http://www.amazon.com/MLCS-9146-Fors...0501631&sr=8-1
    As for a square hole.....router + jig. Basically you will need to create an overlay in another piece of wood and then use a router with a bushing attached (see link below) Then pick your depth and route away. http://www.popularwoodworking.com/te...le_router_jigs , http://www.patwarner.com/mortiser.html
    Another way would be use the forstner bit as mentioned above and then get a wood chisel and chisel out the 4 corners. You just need to be careful with the chisel as they are sharp and can easily split/mar your wood
    3. And a couple of other helpful hints.......A) always wear safety glasses - as 1080p isn't going to look quite as good if you lose an eye B) prior to cutting plywood, take a utility knife and trace the edges of the cut. By doing this you are cutting the top layer and will minimize tear out on the plywood. (you don't need to do this with MDF) C) Draw in pencil - if you need to erase - use a cloth + rubbing alcohol. It will remove the pencil marks and won't harm the wood. D) jigs are your friend. There are a ton of different jigs out there. It may take some extra time to create - but it will make your cuts much easier. Just google Jigs, Saw Jigs, Router Jigs, Table Saw Jigs, etc. and you can get detailed plans on how to construct. E) Let the tool do the work, don't force/push the tool - that's how accidents happen.
    Good luck and look forward to your progress.
  9. #9
    Join Date
    Aug 2011
    San Francisco, USA
    Thanks
    Default
    Wow, dante and mameman, you guys rock. Totally awesome advice. I'm gonna use your tips and post some photos of my results. And hopefully, other woordworking newbies like myself can refer to this in the future. Thanks a TON!!!
    My MPT3k Pin Build
  10. #10
    Elite Member gbeef's Avatar
    Join Date
    Aug 2010
    Canada
    Thanks
    Default
    You guys with your 46" screens DAM i want to do another build!
    My Cabs
    My Pin Cab Attack of the PINZ cab
    My Racing Cab OutRun Racing
Similar Threads
  1. 47/30/19 Widebody build
    By Numiah in forum HyperPin Cabinet Forum
    Last Post: 02-15-2012, 10:26 AM
  2. Widebody lockdown bar
    By granter in forum HyperPin Cabinet Forum
    Last Post: 02-24-2011, 07:53 PM
  3. Looking for a widebody cab in Pittsburgh
    By transfan in forum HyperPin Cabinet Forum
    Last Post: 05-25-2010, 05:21 AM
  4. Widebody 40" Pin Cab
    By pabloukBT in forum HyperPin Cabinet Forum
    Last Post: 05-02-2010, 11:59 AM
  5. Widebody Lockdown Bar, where?
    By lettuce in forum HyperPin Cabinet Forum
    Last Post: 03-28-2010, 09:53 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
