If not already done, you can try editing your Settings/Settings.ini file and set hide_cursor=true
When I try to launch atomiswave games (demul57) I can see mouse cursor on the screen during loading. Is any trick to hide it ? I tried a few apps but without succes :/. I use the newest settings file from djvj.
You mean settings of hyperspin or settings of atomiswave ?
I just solved the same issue. As the person above mentioned, go into the Settings folder and Settings.ini and make the changes. For me that wasn't enough though. For whatever reason, I had to go into HL itself and click those boxes there as well. That seems to have done the trick.
I edited settings.ini in the settings folder and added "hide_cursor=true" with succesThank you very much for help and time
Bookmarks
