Hyperspin
Reply
Thread Tools Display Modes
Old 05-23-2009, 11:11 AM   #1
cnribbens
HyperNewbie
Default Kega fusion not working right by Sega Master system
Im trying to get all the emulators working properly, but now i got a strange error. If i run sega genesis games kega fusion runs smoothly and i dont get any errors, but if i want to play sega master system i get the display direct3D error. And this is strange because on the genesis its going allright.
So my question is how can i fix this, because if i put my screen in 16 bit mode it will affect the other emulators i think? Thanks in advance guys!
I also tried sega game gear and this also works great. I must say that the games on the sega master system work but only if i clicked the error away and this isnt what i want.
cnribbens is offline   Reply With Quote
Old 05-23-2009, 01:34 PM   #2
dpar
HyperSpin Guru
Default
What exactly is the error you are getting?
dpar is offline   Reply With Quote
Old 05-23-2009, 03:04 PM   #3
cnribbens
HyperNewbie
Default
unable to set display mode
Old 05-23-2009, 04:31 PM   #4
Ego-X
Full Member
Ego-X's Avatar
Default
If you are using a render plugin you might try switching to a standard kega plugin like tv mode or something to see if that help.
Ego-X is offline   Reply With Quote
Old 05-24-2009, 01:27 PM   #5
cnribbens
HyperNewbie
Default
ok i discovered it has to do with the resolution i have got my screen on. So i put it to a lower resolution and it worked now!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
kega fusion 3.63 widescreen? SORHP HyperSpin 3rd Party Applications 7 01-30-2010 03:34 PM
Sega Master System System(THK_10-08-2009) Rating THK HyperSpin Main Forum 6 12-14-2009 04:49 AM
Sega Master System Main/System theme THK Theme Announcements 6 10-17-2009 06:01 AM
Sega Master System Box Art (Full Set) SophT HyperSpin Main Forum 9 02-22-2009 06:28 PM
Sega Master System Box Art Aabra HyperSpin Main Forum 7 09-07-2008 05:33 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. Ad Management plugin by RedTyger
