Hyperspin
Reply
Thread Tools Display Modes
Old 01-28-2010, 06:00 AM   #1
Ggallery
Lurker
Default Sega CD doesnt exit on ESC from same Fusion exe
SMS, Genesis, Gamegear & 32X all exit on ESC via HS, but now that I've tried Sega CD it drops to the window when I hit ESC. I'm booting all of the systems frrom the same Fusion.exe, in the same Genesis folder.
Any ideas?
09:45:48 AM | Excecutable is Fusion.exe
09:45:48 AM | Running in normal rom mode
09:45:48 AM | Executable Found
09:45:48 AM | Rom Found
09:45:48 AM | Attempting to launch
09:45:48 AM | Pausing Animations
09:45:49 AM | Launching file
09:45:49 AM | Command Line is: "E:\HyperSpin\Emulators\Sega Genesis\Fusion.exe" "E:\HyperSpin\Emulators\Sega CD\Terminator, The (1993)(Virgin)(NTSC)(US)[!].cue"
09:49:56 AM | Menu.xml found
09:49:57 AM | Main Menu.xml loaded
09:49:57 AM | Loading wheel images
09:49:57 AM | Entering Menu
09:50:01 AM | Menu.xml found
09:50:02 AM | Sega Genesis.xml loaded
09:50:02 AM | Loading wheel images
09:50:03 AM | Entering Menu
09:50:07 AM | Excecutable is Fusion.exe
09:50:07 AM | Running in normal rom mode
09:50:07 AM | Executable Found
09:50:07 AM | Rom Found
09:50:07 AM | Attempting to launch
09:50:07 AM | Pausing Animations
09:50:08 AM | Launching file
09:50:08 AM | Command Line is: "E:\HyperSpin\Emulators\Sega Genesis\Fusion.exe" -fullscreen "E:\HyperSpin\Emulators\Sega Genesis\roms\Aerobiz Supersonic (USA).zip"
09:51:09 AM | Menu.xml found
09:51:09 AM | Main Menu.xml loaded
09:51:10 AM | Loading wheel images
09:51:10 AM | Entering Menu
09:51:16 AM | Menu.xml found
09:51:16 AM | Sega Master System.xml loaded
09:51:16 AM | Loading wheel images
09:51:17 AM | Entering Menu
09:51:22 AM | Excecutable is Fusion.exe
09:51:22 AM | Running in normal rom mode
09:51:22 AM | Executable Found
09:51:22 AM | Rom Found
09:51:22 AM | Attempting to launch
09:51:22 AM | Pausing Animations
09:51:22 AM | Launching file
09:51:22 AM | Command Line is: "E:\HyperSpin\Emulators\Sega Genesis\Fusion.exe" -fullscreen "E:\HyperSpin\Emulators\Sega Master System\roms\Alien Storm (Europe).zip"
09:52:03 AM | Excecutable is Fusion.exe
09:52:03 AM | Running in normal rom mode
09:52:03 AM | Executable Found
09:52:03 AM | Rom Found
09:52:03 AM | Attempting to launch
09:52:03 AM | Pausing Animations
09:52:03 AM | Launching file
09:52:03 AM | Command Line is: "E:\HyperSpin\Emulators\Sega Genesis\Fusion.exe" -fullscreen "E:\HyperSpin\Emulators\Sega Master System\roms\Choplifter (USA, Europe).zip"
09:53:59 AM | Menu.xml found
09:54:00 AM | Main Menu.xml loaded
09:54:00 AM | Loading wheel images
09:54:00 AM | Entering Menu
09:54:05 AM | Menu.xml found
Ggallery is offline   Reply With Quote
Old 01-28-2010, 07:08 AM   #2
Zinger19
Full Member
Zinger19's Avatar
Default
Set hyperlaunch to True in HyperHQ
Zinger19 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
can exit sega or TG-16 daggerlee HyperSpin Support 8 11-23-2009 11:05 PM
Kega fusion not working right by Sega Master system cnribbens HyperSpin Support 4 05-24-2009 01:27 PM
Fusion 3.61 Sega CD issue rangel HyperLounge - Off Topic Discussion 5 04-22-2009 05:55 AM
Sega Fusion problem daggerlee HyperSpin Support 3 03-22-2009 06:58 PM
sega game gear skin in fusion magostin HyperSpin Main Forum 6 10-21-2008 04:35 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. Ad Management plugin by RedTyger
