Hyperspin
Reply
Thread Tools Display Modes
Old 09-14-2008, 06:54 PM   #1
Dazz
Administrator
Dazz's Avatar
Send a message via AIM to Dazz Send a message via MSN to Dazz Send a message via Yahoo to Dazz
Default We need a MAME Default theme. Post your attempt in this thread!
I just realized that we really do not have a default MAME theme... Below is what I am currently using that I just threw together in 2 seconds this evening. It definitely does not do a HyperSpin MAME Default theme justice, but it isn't bad.
Please post your default MAME theme below and we'll see if we can get some good ideas going around.
Also, for a default theme you don't want many animations as you will have to see them over and over. My theme nothing is animated right now as it is just a basic default theme. Post what you have!
Click image for larger version
Dazz is offline   Reply With Quote
Old 09-15-2008, 09:22 AM   #2
Ego-X
Full Member
Ego-X's Avatar
Default
I threw this together for mine, similarly I didn't upload to HS because it's not really good enough for public consumption.
Ego-X is offline   Reply With Quote
Old 09-15-2008, 10:43 AM   #3
The Loafer
I took this pic :)
The Loafer's Avatar
Default
I was considering making one but having my own cab as the pic, similar to the default NeoGeo theme, so when a flv is playing on the "monitor", it is my own.
Both your themes would do the job, I don't necessarily agree with the need to limit animations, but yeah, I guess they could get monotunous. I would probably still create the "game.xml" and simply give it a few random different animations, maybe 5 different types for the rest of the games (yeah, hardly "default" anymore).
__________________
(this space available for rent)
The Loafer is offline   Reply With Quote
Old 09-25-2008, 07:07 AM   #4
starbuck
Lurker
Smile Mame default themes
Would like to use one of the mame default themes that you guys are showing. Could you please post them with the needed ini files etc, so that they could be used.
Thanks
Starbuck
starbuck is offline   Reply With Quote
Old 09-25-2008, 02:45 PM   #5
urbecrisch
Full Member
Default
How does one go about using a default theme in HS? Is there a setting that needs to be changed? It seems the only way to use the default theme is to rename the default theme for each game in the .xml list. Is this true or am I missing something here?
urbecrisch is offline   Reply With Quote
Old 09-25-2008, 02:58 PM   #6
BadBoyBill
Administrator
BadBoyBill's Avatar
Default
Any game that has a theme made will have a gamename.xml file in the themes folder for that system.
When a game doesnt have a theme.xml then it is not considered a theme and will revert to the default settings which are found in the ini file for that system.
A scenario would be that you have maybe some boxarts in one of your artwork folders. Your database is populated with some games. Then when you go into that system those games boxarts will animate in by default using the animation settings in the ini file even though none of those games have a theme available yet by one of the theme creators.
BadBoyBill is offline   Reply With Quote
Old 09-25-2008, 08:40 PM   #7
urbecrisch
Full Member
Default
Ahh, I think I get it. Will check out the default properties at a later date. Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Default MAME theme ACE Graphic & Theme Creation 6 09-22-2009 05:16 PM
mame default theme use swf ??? lole Graphic & Theme Creation 13 05-14-2009 06:15 AM
Mame Game Default Theme urbecrisch HyperSpin Main Forum 2 03-28-2009 09:35 PM
MAME Default Theme - New Artwork DukeofCrydee Graphic & Theme Creation 1 02-21-2009 09:30 PM
default mame theme cathaldub HyperSpin Support 0 01-18-2009 03:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. Ad Management plugin by RedTyger
