Media Player Starting using Daemon Tools Sega Saturn Plus More
tonycrew
How can i stop WMP starting when Daemon Tools Mounts a Saturn Game..?
Also the emu screen is taller than the Bezel, its ok at the top but is lower that than bezel, i have options set to Full Screen for Bezel and for SSF i notice you can adjust for this in an offset in the Module Setting but it just says make the number higher or lower and there is no number, so i don't know where my starting point is.
 And also the Bezels, Don't go to the bottom of the screen, my task bar is set on AutoHide but there's a small gap.
Running Win 7 x64
 The Last Hyperspin 3.? before it became Rocketlauncher
And Hyperspin 1.3 not the new beta.
Some Sega Saturn games have audio tracks in which WMP wants to play.  To prevent WMP from autostarting, go to Start->Control Panel->Hardware and Sound-> Under Autoplay select change default settings for media or devices....and in there you would select take no action in the dropdown under Audio CD/Enhanced Audio CD
Not sure with bezels as I havent set them up....someone else will need to chime in
  • 1 year later...
