Download Section Back Up, Navigate the Right Hand Menu to find files, ignore the 0s
how to get full screen and centered with genesis emulator?
zerocool420
I set up my retroarch and followed the video tutorial from simply Austin to set up my genesis but I cant get my screen to go full and center up in the bezel.  when I start it now, the screen is in the upper left hand position.  any help would be appreciated, thanks!!
Link to comment
Share on other sites
  • 1 year later...
Guest rynoman03
Great Advice!
Question though.
1. Do most of you folks keep a 4:3 ratio or if you are using a widescreen do you go ahead and do the 16:9.
    I understand anything but 4:3 isn't the true game ratio. Well at least in my opinion.
2. I found where to change the aspect but how do I get RetroArch to apply this to all of my Sega X32, Sega Genesis games, and Nintendo Games?
Link to comment
This is probably an issue with the bezel ini file. Check it to see if the coordinates are correct. If anything, set them to 0, 1, 1920, 1080 (ex for 16:9 1080p screen) and it should display in full size, centered on the screen with the bezel.
I always run the games in their original aspect ratio. In RetroArch I have the configs set to use "core provided" ratio.
You probably have RocketLauncher set to look for core specific config files (which is the way to go, in my opinion). You should create or update all of the different config files to have these same settings.
Link to comment
Guest rynoman03
Would this be easiest done with Notepad++ to the config file or actually launch RetroArch and make a save to the config?
Honestly I'm still trying to figure out RetoArch. I'm sure there is a way to set what Console to launch X config. I'm just missing that step somewhere along the line.
I've been following SimplyAustin's setups via YouTube and i've got most of the hang of things but i'm still learning or relearning.
Also having some issues getting my N64 games to center into the Bezel. Another challenge :)
Link to comment
Guest rynoman03
Got it. I got ahold of SimplyAusin as well. He told me to re-watch his RA video. I found what I was missing. I knew you had to make the change in RA then save the config but I wasn't understanding how to use the config once changed. I get it now :) Thanks mate!
PS: I made a little snippet below in case others have the same issue.
Link to comment
  • 4 months later...
