Nvidia Sheild Tv setup
sandog
Hello All
                I Already have a working copy of Hyperspin running on my pc and was wanting to setup my Sheild Tv to run it from looking at the setup for hyperspin there is a setting pack that I have to use for android but I'm sure if i install that pack my pc will not work correct. So if someone can point me in the right direction that would be awesome I'm sure I'm not the first asking the question.
In theory, you should be able to connect an external USB drive or copy your Hyperspin folder to the Shield TV's hard drive (if you have the PRO model).     You'll need to edit the settings.ini files to match your emulators, rom extensions and rompath.   Other common issues are '&' symbols in the dbase file.    Work through each system/wheel at a time and report back if you can't figure something out.    I posted some example ini files to this site and posted other helpful info as sticky-posts.
