No XML in RLUI Database Folder.
mccorkled
My system has been working fine for quite a while. I decided to switch to the Aeon Nox XIII skin and when I try to launch a game I get this message. I looked in that directory and there are no XMLs but I am pretty certain there were never any in there before, I would not have deleted them. What's going on?
My system XML is in Z:\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml  like it always has been.
Thanks.
So you also did an update of Rocketlauncher right? There were some new additions. Check out Simply Austin's latest vid here or goto the Rocketlauncher forums to get a fx for your solution.
Hmmm, yes actually. I did update it just the other day. I love when updates break a system that took me years to build. I have nothing but spare time.  :wallbash:
Have you set HyperSpin as the default front end? RocketLauncher now supports front ends other than HyperSpin and you need to tell it which one to use. It's currently defaulting to use RLUI as the front end. Hence the issue.
There's some great support given over at the RocketLauncher forums. :) If you get any more issues, grab the RL log and make a post. :)
It has always supported other from frontends.
Yeah kind of, since it changed over to rocket launcher.
Either way, the problem is the same here. Set HyperSpin as the default front end and sorted.
The change you need to make with the update is listed at the top of the update announcement/notes.
http://www.rlauncher.com/forum/showthread.php?2037-RocketLauncher-v1-0-1-4
I'm just going to check the notes before updating from now on.
It didn't break it and the update has nothing to do with that specific system. Two simple boxes in rlui you have to set.
The first time I have approved of your bluntness. haha
Thanks. I am going to try the fix(es) tomorrow.
Edit: Got it working.
Thanks guys.
