Setting up wheel size for android
badhemi
Most parameters in the Android build are fixed/static and so many changes to .ini files may be ignored (at this time).
You can read through the 'known issues' sticky post.   If it's unclear, then go ahead and experiment with some of the parameters in <system>.ini or 'main menu.ini' to see if they help.
I do believe several of the text parameters are hooked up but I can't recall if the image parameters are... (per wheel)
thanks
