daphne help
craiganderson
Hello,
Have all the Daphne games working exept
1) GP World - video has flashing green squares during intro. then sorta freezes and goes weird black and white when game starts. freezes
2) Thayer's Quest - gets stuck on "your time is running out, add more quarters" screen ...... but really cant do anything to get off that screen.....but the program speaks whatever key i hit while stuck on that screen.....
daphne logs to follow
GP WORLD
--DAPHNE version 1.0.12
--Command line is: C:\HyperSpin\Emulators\daphne-1.0v-win32\daphne.exe gpworld vldp -blank_searches -prefer_samples -fullscreen -noissues -opengl -fastboot -x 800 -y 600 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile C:\HyperSpin\Emulators\daphne-1.0v-win32\framefile\gpworld.txt
--CPU : GenuineIntel 3000 MHz || Mem : 4096 megs
--OS : Windows NT Derivative || Video : Intel® HD Graphics
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting alternate home dir:
Setting screen width to 800
Setting screen height to 600
Setting sound buffer size to 2048
Set 800x600 at 32 bpp with flags: 80000002
Initializing sound system ...
Joystick #0 was successfully opened
Remapping input ...
Loading compressed ROM image gpw_6162a.bin...16384 bytes read.
Loading compressed ROM image gpw_6163.bin...16384 bytes read.
Loading compressed ROM image gpw_6164.bin...16384 bytes read.
Loading compressed ROM image gpw_6148.bin...4096 bytes read.
Loading compressed ROM image gpw_6149.bin...16384 bytes read.
Loading compressed ROM image gpw_6150.bin...16384 bytes read.
Loading compressed ROM image gpw_6151.bin...16384 bytes read.
Loading compressed ROM image gpw_6152.bin...16384 bytes read.
Loading compressed ROM image gpw_6153.bin...16384 bytes read.
Loading compressed ROM image gpw_6154.bin...16384 bytes read.
Loading compressed ROM image gpw_6155.bin...16384 bytes read.
Loading compressed ROM image gpw_6156.bin...16384 bytes read.
Loading compressed ROM image gpw_6157.bin...16384 bytes read.
Loading compressed ROM image gpw_6158.bin...16384 bytes read.
Loading compressed ROM image gpw_6146.bin...32 bytes read.
Loading compressed ROM image gpw_6147.bin...256 bytes read.
Loading compressed ROM image gpw_5501.bin...256 bytes read.
Framefile parse succeeded. Video/Audio directory is: C:/HyperSpin/Emulators/daphne-1.0v-win32/VLDP/Laser GP/
OpenGL v2.0 is supported.
Booting ROM ...
LDV1000: Reject received (ignored)
OGG ERROR : Your .ogg file needs to have 2 channels and 44100 Hz
OGG ERROR : Your .ogg file has 2 channel(s) and is 48000 Hz
OGG ERROR : Your .ogg file will be ignored (you won't hear any audio)
Play
Display disable received
Unsupported LD-V1000 Command Received: f2
Search to 5041 received
search succeeded d0
LDP : Received pause while disc was not playing, ignoring
Play
LDP : disc is already playing, play command ignored
Play
Search to 6631 received
search succeeded d0
Play
Play
Pause
Search to 16381 received
search succeeded d0
Play
Play
Search to 16890 received
search succeeded d0
Play
Pause
Play
Pause
Shutting down sound system...
Shutting down video display...
THAYERS QUEST LOG
--Command line is: C:\HyperSpin\Emulators\daphne-1.0v-win32\daphne.exe tq vldp -blank_searches -prefer_samples -fullscreen -noissues -opengl -fastboot -x 800 -y 600 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile C:\HyperSpin\Emulators\daphne-1.0v-win32\framefile\tq.txt
Remapping input ...
Loading compressed ROM image tq_u33.bin...32768 bytes read.
Loading compressed ROM image tq_u1.bin...8192 bytes read.
Loading compressed ROM image tq_cop.bin...1024 bytes read.
Framefile parse succeeded. Video/Audio directory is: C:/HyperSpin/Emulators/daphne-1.0v-win32/VLDP/tq/
Booting ROM ...
ERROR: CPU port 80 write requested (value f5) at pc de
Play
Play
Warning: generic input_enable function called, does nothing
Warning: generic input_disable function called, does nothing
Search to 696 received
NOTE: converting FPKS from 29970 to 23976. This may be less accurate.
search succeeded d0
Search to 49361 received
search succeeded d0
Play
Search to 49103 received
search succeeded d0
Freeing memory used to store audio stream...
Craig,
For GP World:
Try changing the Hardware Acceleration to YUV Hardware Overlay and post your framefile please.
Ron
Craig,
For Thayer's Quest:
The game is operating correctly. It's asking you to enter your name. The voice is speaking back the letters you hit.
I found this resource:
Daphne Wiki: http://www.daphne-emu.com/mediawiki/index.php/Main_Page
How to start the game:
1: After I launch Daphne, I wait for the animation to start.
2: I hit 5 and then 5 again to enter 2 credits
3: After a short pause, I get the scren that reads "Insert more coins for more time" or something, & the voice says to press any key to continue.  At this point, let me ask if you can hear the synthesized voice--I had trouble w/ the voice being quiet for a while (which I think I solved by turning up the volume).  Make sure you can hear it--you should hear it speak some nonsense line (about a laser disc self-test?) when you first see something on-screen
4: I hit key 1 (any key on that keyboard pic ought do...)
5: the voice asks me to type in my name.  I type J A S O N, then I hit F3 for "enter"
6: the voice speaks my name & asks me to confirm it.  I hit 1 for "yes"
Then animation starts & the game is on!
Thayer's Quest keys cannot be changed as of the time of this writing.
F1 	Choice #1 (triangle) / Clear
F2 	Choice #2 (circle)
F3 	Choice #3 (square) / Enter (NOTE : the regular Enter key on the keyboard does nothing)
F4 	Choice #4 (pentagon) / Space (NOTE : the regular spacebar on the keyboard does nothing)
F5 	Insert Coin
F6 	Insert Coin
1 	Yes
2 	Items
3 	Drop Item
4 	Give Score
5 	Replay
6 	Combine Action
7 	Save Game (NOTE : saving games is not supported at the time of this writing)
8 	Update
9 	Hint
0 	No
A - None			N - Staff		0 - No
B - Silver Wheat		O - Crystal		1 - Yes
C - Spell Of Seeing		P - None		2 - Items
D - Great Circlet		Q - None		3 - Drop Item
E - Black Mace			R - Blood Sword		4 - Give Score
F - Hunting Horn		S - Dagger		5 - Replay
G - Long Bow			T - Chalice		6 - Combine Action
H - Medallion			U - Cold Fire		7 - Save Game
I - Crown			V - Shield		8 - Update
J - Onyx Seal			W - Amulet		9 - Hint
K - Orb of Quoid		X - Scepter		F1 - 1/Clear
L - None			Y - Coins		F2 - 2
M - Spell Of Understanding	Z - Spell Of Release	F3 - 3/Enter
						F4 - 4/Space
Here is the keyboard layout:
Craig,
For Thayer's Quest:
F5 	Insert Coin
F6 	Insert Coin
1 	Yes
2 	Items
3 	Drop Item
4 	Give Score
5 	Replay
6 	Combine Action
8 	Update
9 	Hint
0 	No
						F4 - 4/Space
[ATTACH=CONFIG]33766[/ATTACH]
thank you
that worked
never would have figured that out....
that will be a hard one to set up on x-arcade or xbox controller......lol
thanks
craig
Craig,
You are right there. I would love have an original membrane keypad for Thayer's Quest!
Maybe I can hack up an old keyboard and do something like this: http://www.hyperspin-fe.com/forum/showthread.php?22180-My-Thayer-s-Quest-themed-keyboard
Craig,
I don't know if that's the problem or not. But in DaphneLoader, select GP World and click on Configure on the right. In the Video tab, you can change the Hardware Acceleration. Then try to run it through DaphneLoader. Let me know what you see.
It was already set to that setting but i changed it ....then changed it back and tried again
no sound
lots of green flashing squares (taking up 1/4 of video)
Remapping input ...
Booting ROM ...
Play
search succeeded d0
Play
Play
search succeeded d0
Play
Play
Pause
Search to 27691 received
search succeeded d0
Play
Play
Search to 28128 received
search succeeded d0
Play
Pause
Play
Pause
LDV1000: Forward 1X (muted)
Play
That sounds like you may have a bad ogg file? Also, I see a green box on mine as well. I believe it's looking for a graphic of the tracks that are not there. The only one that works for me is to enter coin and hit start with the green box in the upper left corner. I get much the same as you in the way of log, but without the ogg error. The game runs and plays fine, but the audio is not there, even though I don't get that ogg error.
After some additional research I have found there are two different games. The one Craig has is Laser Grand Prix. The other is called GP World. They are two completely different games. That could be the issue I have been having with the video. I am running Laser Grand Prix through Daphne as if it were GP World. Both Craig and I have LGP. When I run the GP World video/audio files, they run correctly. Laser Grand Prix may have gone by the wayside like Goal-To-Go. :(
Just some FYI,
Ron
Just some FYI,
Ron
thanks
ok
switched to GP world instead of Laser grand prix....
game plays
starts off with sound
but then sound goes away
but video and game continues correctly as far as i can tell....
thanks everybody
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: C:/HyperSpin/Emulators/daphne-1.0v-win32/VLDP/GP World/
Booting ROM ...
Play
search succeeded d0
Play
Play
search succeeded d0
Play
Play
Pause
Search to 7231 received
search succeeded d0
Play
Play
Search to 7531 received
search succeeded d0
Play
Pause
Play
Pause
Play
Successfully changed speed to 1/1X
Successfully changed speed to 1/2X
Successfully changed speed to 2/1X
Successfully changed speed to 3/1X
Unmapped write to dac0 with value 48 (PC is 60d6)
Pause
Play
Pause
Play
Pause
Play
Unmapped write to dac0 with value ff (PC is 3cdb)
Search to 27541 received
search succeeded d0
Play
Pause
Search to 26341 received
search succeeded d0
Play
Pause
search succeeded d0
Play
Play
Pause
search succeeded d0
Play
Play
search succeeded d0
Play
Pause
Play
Pause
Play
Craig,
Glad to hear it. Congrats!
Ron
  • 8 months later...
Have problem have all Dahpne games running but GP World. If I run it with Dahpneloader it works fine, but when I open it in Hyperspin it said can't find lasergp.m2v don't know y its looking for that seeing every thing is named gpworld in framfile folder please help.
That sounds like a framefile issue. Where are your framefiles located?
Run the game through DaphneLoader and post the Daphne log. Then run it through HyperLaunchHQ and post your HyperLaunch log. Here is a post that explains how to post:
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
It would be helpful to post what version of HyperSpin, HyperLaunch and the Emulator.
Thanks,
Ron
Thanks,
Ron
all my framefiles are in framefiles folder. I have tried renaming the files to lasergp and it works with the dahpneloader, same if I rename everything to gpworld working in dahpneloader. but not in hyperlaunch when I run test.
--Command line is: D:\HyperSpin\Emulators\Daphne\daphne.exe gpworld vldp -blank_searches -prefer_samples -noissues -fastboot -fullscreen -x 1024 -y 768 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile D:\HyperSpin\Emulators\Daphne\framefile\gpworld.txt
--CPU : GenuineIntel 3250 MHz || Mem : 4096 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce GTX 275
Setting screen width to 1024
Setting screen height to 768
Set 1024x768 at 32 bpp with flags: 80000001
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/Daphne/framefile/./
Could not open file : D:/HyperSpin/Emulators/Daphne/framefile/./lasergp.m2v
Could not initialize laserdisc player!
Sorry about that first log is if I try running it whit hyperlaunch. This log is with dahpneloader.
--Command line is: daphne.exe gpworld vldp -framefile D:\HyperSpin\Emulators\Daphne\framefile\lasergp\lasergp.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir D:\HyperSpin\Emulators\Daphne -sound_buffer 2048 -x 640 -y 480
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 0
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/Daphne/framefile/lasergp/./
YUV overlay is done in software (ie unaccelerated).
Booting ROM ...
Play
search succeeded d0
Play
Play
Ok. First thing. Please use Code tags when posting logs. Take a look at the link I posted on how to do so. Posting logs without code tags will mess up the display and make the posts long and hard to read. See my reply below with code tags used.
Remapping input ...
This is the command line from HyperLaunch:
--Command line is: D:\HyperSpin\Emulators\Daphne\daphne.exe gpworld vldp -blank_searches -prefer_samples -noissues -fastboot -fullscreen -x 1024 -y 768 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile D:\HyperSpin\Emulators\Daphne\framefile\gpworld.txt[/Code]
Notice the location and name of the framefile?  The broken framefile.Sorry about that first  log is if I try running it whit hyperlaunch.  This log is with dahpneloader.
[code]
Remapping input ...
Booting ROM ...
Play
search succeeded d0
Play
Play
And from DaphneLoader:
Again, notice the different framefile location and name?? This is the correct framefile?
Rename the file
to something else like gpworldbu.txt and copy the file
D:\HyperSpin\Emulators\Daphne\framefile\lasergp\lasergp.txt[/Code]
  to the directory
[code]D:\HyperSpin\Emulators\Daphne\framefile\
and name it gpworld.txt
Test again and let me know.
Thanks,
Ron
ok so I put every thing back to the way it should be. this with Dahpneloader and working
--Command line is: daphne.exe gpworld vldp -framefile D:\HyperSpin\Emulators\Daphne\framefile\gpworld\gpworld.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir D:\HyperSpin\Emulators\Daphne -sound_buffer 2048 -x 640 -y 480
--CPU : GenuineIntel 3300 MHz || Mem : 4096 megs
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: D:/HyperSpin/Emulators/Daphne/framefile/gpworld/./
Booting ROM ...
Play
search succeeded d0
Play
Play
Search to 5401 received
search succeeded d0
Play
Play
This one with hyperlaunch not working, it dos not seem to matter what the name is or I'm not under standing you. Don't know y hyperspin changes the directory ? My files on hard drive are in D:\HyperSpin\Emultors\Dahpne\framefile\gpworld\gpworld.txt
I was just trying the "lasergp" renameing because it was look for it I don't understand it ?
Remapping input ...
HOLLY @$%@ % %$#@ GOT IT Working!!!!
This is the working log from Dahpne running in hyperspin. Unfortunately not sure how I did it, but I think it was the framefile which looked like this
4666 gpworld.m2v
51210 gpdiags.m2v
and I changed it to
4666 gpworld.m2v
51210 gpdiags.m2v
But also when thorgh HQ and launchHQ and check all setting, could have maybe reset some thing by trying to use hyperspin in normal mode and then changing it back to hyperluanch in HQ. Maybe a hyperspin guru can tell from log file what I did and help the next poor soul.
Thank you so much rfancella for your help on this.
--Command line is: D:\HyperSpin\Emulators\Daphne\daphne.exe gpworld vldp -blank_searches -prefer_samples -noissues -fastboot -fullscreen -x 1024 -y 768 -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -framefile D:\HyperSpin\Emulators\Daphne\framefile\gpworld\gpworld.txt
Remapping input ...
Booting ROM ...
Play
search succeeded d0
Play
Play
