Adding PS4 and XBOX One Remote Play to Hyperspin
diskmach
Now that you can Remote Play PS4 to PC as well, I set out to add both PS4 and XBOX One
Remote Play to Hyperspin.
PS4 is straight-forward, added it as an exe in HyperHQ, just need a freaking long cable to connect
the PS4 controller to PC. Well, don´t ask, my setup is a bit weird, with long HDMI-cables going in every direction,
with the possibility to bring up Hyperspin, etc, on various screens in a few rooms.
But with XBOX One it seemed slightly more complicated, as the XBOX App is a Metro app.
I was able to make a shortcut to the app, with the help of this:
But it´s not like this gives me the path to the app to write down in HyperHQ.
I didn´t know that this was the case, but I could just add the "Xbox shortcut.lnk" as the executable
in HyperHQ.
My Hyperspin profile has mouse control, so that I can click around to get into the frontends.
And that´s pretty much it, done in 15 mins...
I can't believe no one has commented on this. I was thinking about doing this too, but I haven't downloaded the PS4 app yet.
How do you get around the problem of mouse support exactly? I usually map the mouse to the right stick for most PC games, but I picture doing it for the Xbox App and it conflicting whenever I use a right-stick in game.
Cn you remote play either one using just keyboard or do you have to have a controller hooked up?
EDIT: Looks like they require a controller. That puts it out for me since I won't use controllers with an arcade cabinet.
I'd keep an eye on them from time to time. Both systems have said Keyboard/Mouse support is something they'd like to do.
Wouldn't be surprised if this time next year it's possible.
Yeah, PS4 needs to have the PS4-controller connected with a cable to the PC at all times, and Xbox one uses its
own controller that is connected to the Xbox. A bit of a bummer, but I have these lying about anyway.
Sent from my 301F using Tapatalk
I can't check this now, as I'm travelling,
but I think that the Xbox 360 controller with the Hyperspin profile actually did something in the PS4 games. Although you still have to have the PS4 controller connected to the PC...
I have played my Xbox one through my laptop with my X360 controller connected wirelessly to the laptop. You can also plug in the X1 controller to the laptop. I don't have a wireless X1 adapter for PC but i suspect that would work the same way.
I'm back...
So for Xbox One, I'm now using the XBOX 360 controller, as indicated by SkyHighGam3r. I have my "peculiar" setup with Padstarr, see http://www.hyperspin-fe.com/topic/14216-setup-xbox-360-controller-with-padstarr-for-all-of-hyperspin/ ,
so I can switch at will with the guide button between the Hyperspin profile and an empty profile, the empty one then lets the XBOX app built-in profile function in the background. Mouse control is on the Hyperspin profile.
For some reason though, if the XBOX One is in sleep mode, I can't seem to be able to turn it on with the XBOX 360 controller. It says to use "Instant-on" mode and put it on the same network, but those things are already in place.
So I put it on "never shut down automatically", that should take care of that, hope it doesn't use a LOT of extra juice...With that caveat, remote play on XBOX One is fully usable for me with just the XBOX 360 controller, which is what I use normally
for all of Hyperspin.
As mentioned earlier, I can see that the PS4 is reacting to key-presses on the XBOX 360 controller, will try to figure out a setup for this.
Well, it seems that only arrows = direction, escape = circle and enter = cross (or vice versa, I have a japanese PS4) are implemented for the keyboard in PS4 Remote app. And not even that in some games. So back to the original setup...For now...
