Download Section Back Up, Navigate the Right Hand Menu to find files, ignore the 0s
Help with Settings file Tutorials project
thatman84
Hi all, so im trying to put together some tutorials to upload for approval and wanted to get some help with it if you can.
Its a Hyperspin core tutorial but aimed towards Android users and people that dont have access to HyperHQ (Android users with only OSx PC's for example)
Going to do this for the core settings files, Global Settings.ini, Main Menu.ini, Settings.ini and SYTEMNAME.ini
Black Text = Setting
Green Text = Example Value
Red Text = Explanation
Blue Text = Possible Values
THIS IS A 1st DRAFT and needs soem editing by myself, but just need some of the blanks filling in if the community can help me out that would be awesome.
Global settings ini
<I don’t believe anything in here is required for Android but worth annotating anyway>
[HyperLaunch]
Hide_Cursor=false
Fade_In=false
Fade_Out=false
Fade_Color=0x000000
Fade_In_Duration=500
Fade_Out_Duration=500
Fade_In_Delay=0
Keymapper_Enabled=false
Keymapper=
Hide_Desktop=false
Hide_Taskbar=false
CPWizard_Enabled=false
CPWizard_Delay=8000
CPWizard_Params=minimized -timeout 9000
7z_Enabled=false
7z_Extract_Dir=C:\Users\toby\AppData\Local\Temp\Hyperspin\
7z_Delete_Temp=true
MultiGame_Enabled=false
MultiGame_Background_Color=FF000000
MultiGame_Side_Padding=0.2
MultiGame_Y_Offset=500
MultiGame_Image_Adjust=1
MultiGame_Font=Arial
MultiGame_Text_1_Options=x10p y30p w80p Centre cBBFFFFFF r4 s100 Bold Italic
MultiGame_Text_1_Text=Please select a game
MultiGame_Text_2_Options=w96p cFFFFFFFF r4 s50 Center Bold Italic
MultiGame_Text_2_Offset=70
MultiGame_Use_Sound=true
MultiGame_Sound_Frequency=300
MultiGame_Exit_Effect=none
MultiGame_Selected_Effect=rotate
MultiGame_Use_Game_Art=false
MultiGame_Art_Folder=Artwork1
Main menu ini
[wheel]
alpha=0.8 <changes the visibility of the menu wheel in relation to theme artwork. Values 0 = invisible 1= visible>
small_alpha = 1 ???
style=vertical <changes the layout of the wheel possible, values vertical, normal, horizontal>
**Not Supported on Android, Always vertical**
speed=high <speed of wheel scrolling, values = Low,Medium,High)
vert_wheel_position=right <screen placement of wheel. Values = right, centre, left>
**Not Supported in Android, always right**
norm_large=468 <Size of system wheel pointer has landed on, Value between 0 & 1100>
norm_small=230 <Size of other wheels visible but not selected by pointer, Value between 0 & 1100>
vert_large=400 <same as above>
vert_small=230 <same as above>
pin_large=500 <same as above>
pin_small=200 <same as above>
horz_large=400 <same as above>
horz_small=100 <same as above>
horz_wheel_y=700 <horinzontal wheel vertical position, Value = any pixel height>
**Text is not supported for main menu wheel in Android**
text_width=700 < the larger the width the smaller the text will show on the wheel, Value between 500 & 2000>
text_font=Style5 <font style, Values = Style1-5>
small_text_width=200 <width of smaller image text, Value 100-1100, >
large_text_width=400 <width of larger image text, Value 100-1100, the larger the width the smaller the text will height will become >
text_stroke_size=7 <size of outer text border, Value between 0 & 16>
text_stroke_color=0x000000 <text border color, Hex value colors>
text_color1=0x00BFFD <text can comprise of 3 Hex value colors>
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=149 <the display priority/merging of the 3 colors, Value between 0 &254>
shadow_distance=6 <distance text shadow is away from the text, Value between 0 & 20>
shadow_angle=45 <position of text shadow, Value between 0 & 360, 280 = top, 100 = bottom>
shadow_color=0x000000 <Hex value color>
shadow_alpha=1 <visibility of shadow, Value between 0 & 1>
shadow_blur=0 <Value between 0 & 15>
[pointer]
animated = true <pointer will bump when moving wheel, Value true or false>
x= 965 <horizontal position of pointer>
y = 384 <vertical position of pointer>
[video defaults]
path=E:\Hyperspin\Media\Main Menu\Video\  <not fully sure, wanted to add relative path examples>
[sounds]
game_sounds=false <true or false>
wheel_click=true <true or false>
[special Art A]
default=false <???>
active=true <displayed or not,Values true or false>
x = 512 <horizontal position after animation, Value different per artwork>
y=384 <vertical position after animation, Value different per artwork>
in = .4 <time it takes the artworks to animate in to position, any value between 0 & 3 .1          increments>
out = .4 <time it takes the artworks to animate in to position, any value between 0 & 3 .1        increments>
length  = 3 <length of time artwork stays in position before animating out, Values = .2 increments between 0 & 6>
delay  = .1 <the amount of time to wait between animations, values between 0 & 30>
type=fade <style of animations, values = normal, fade or bounce>
start = bottom <screen location where animations enter from>
[special Art B] <same as Special Art A>
default=false
active=true
x = 512
y=384
in = .4
out = .4
length  = 3
delay = .1
type = fade
start = none
Link to comment
Share on other sites
