kratos_spartan Posted June 25, 2016 Share Posted June 25, 2016 Hi guys! i'm having a problem when i try to launch Demul, using RocketLauncher, to play Naomi games, if i set the demul 0.5.8 ahk when i launch a game a message shows saying that "gpu plugin is not supported" i can't figure how to fix this, and if set demul 0.7 ahk this error shows up, plaease somebody who can tell me how to fix this so i can finish with this headache. Link to comment Share on other sites More sharing options...
Metalzoic Posted June 25, 2016 Share Posted June 25, 2016 if i set the demul 0.5.8 ahk when i launch a game a message shows saying that "gpu plugin is not supported" // if set demul 0.7 ahk this error shows up So which version of the emulator are you actually using? 5.8 or.7? Link to comment Share on other sites More sharing options...
bdove67 Posted June 25, 2016 Share Posted June 25, 2016 Do you have Demul working outside of Rocketlauncher ok? Have you looked at the module to try to select another GPU plugin? Link to comment Share on other sites More sharing options...
kratos_spartan Posted June 26, 2016 Author Share Posted June 26, 2016 Do you have Demul working outside of Rocketlauncher ok? Have you looked at the module to try to select another GPU plugin? Yes i did and still shows the same message, i have Demul 0.7 but i've been trying differents modules to see if works but no luck. also i have rocketlauncher updated but again no luck. so i don't know what to do, the emulator by itself works perfect but i find a way to launch Demul running the roms thanks to a couple of commandlines writen on a txt file and saving it as .bat so i set it on HyperHQ as the exe file instead of demul.exe in the wheel settings tab and setting the execution as normal instead of hyperlaunch/rocketlauncher, it's working yes not how i would like to but i can play and i think that it's all that matters in the end. Link to comment Share on other sites More sharing options...
