RetroArch
adamg
So due to unfortunate events lately, I have lost most of my hyperspin setup.  In trying to get everything back to normal, I thought it might be a good time to switch over the RetroArch as it seems pretty simple to keep everything up to date.  Unfortunately I have hit a wall.  I have setup RetroArch as though it were any other emulator, made sure it ran outside of RocketLauncher and everything works great.  When I try to launch anything through RL however, I get an error as seen below:
http://imgur.com/YLmcKoc
I am not using the correct version of the emulator as there have been amazing updates since the 2015 version the module seems to like.  I also have fade off, none of the notes in the module are out of the norm it does not seem.  Log is as follows:
[code]
07:57:07:162 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
07:57:07:162 | RL |   WARNING  | +0     | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
07:57:07:252 | RL |      INFO  | +93    | Main - System Specs:
					RocketLauncher Dir: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 10 Home
					SKU: Windows 8
					Total Memory: 12222.57 MB
					Free Memory: 5155.06 MB
					Used Memory: 7067.512 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 8
					GPU 1 Name: NVIDIA GeForce GTX 750 Ti
					GPU 1 RAM: -2048.00 MB
					GPU 1 Driver Version: 10.18.13.5354
					Sound 1 Device: NVIDIA High Definition Audio
					Sound 1 Status: Enabled
					Sound 2 Device: IDT High Definition Audio CODEC
					Sound 2 Status: Enabled
					System Locale: en-US
					Formats Locale: en-US
					Windows UI Language: en-US
					Text Encoding: Windows-1252
					OS Admin Status: No
					RL Compatibility Flags:
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape]  (Primary)
					Current AHK Desktop Width: 1920
					Current AHK Desktop Height: 1080
					Monitor #1 DPI: 100
					ErrorMode: 0
					AutoHotkey Path:
					AHK Version: 1.1.13.00
					Unicode: No
07:57:07:252 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\RocketLauncher.exe exists
07:57:07:253 | RL |      INFO  | +0     | Main - Raw CLI received: "-s Nintendo Entertainment System -r Adventure Island 3 (USA) -f C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1"
07:57:07:253 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
07:57:07:253 | RL |      INFO  | +0     | Main - RocketLauncher received "Nintendo Entertainment System" and "Adventure Island 3 (USA)"
07:57:07:259 | RL |      INFO  | +0     | Main - Did not find a "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options.
07:57:07:259 | RL |      INFO  | +0     | Main - Adventure Island 3 (USA) is using the default emulator: RetroArch
07:57:07:259 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Nintendo Entertainment System\Emulators.ini
07:57:07:259 | RL |      INFO  | +0     | Main - Checking for a [RetroArch] section in C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Global Emulators.ini
07:57:07:260 | RL |      INFO  | +0     | Main - Found [RetroArch] in C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Global Emulators.ini
07:57:07:260 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists
07:57:07:264 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
07:57:07:264 | RL |      INFO  | +0     | Main - Adventure Island 3 (USA) will use module: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Modules\RetroArch\RetroArch.ahk
07:57:07:267 | RL |   WARNING  | +16    | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Global RocketLauncher.ini"
07:57:07:267 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Settings\Nintendo Entertainment System\RocketLauncher.ini"
07:57:07:287 | RL |      INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
07:57:07:290 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.exe exists
07:57:07:290 | RL |      INFO  | +0     | Main - INI Keys read
07:57:07:290 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\7z.exe exists
07:57:07:291 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\7z.dll exists
07:57:07:297 | RL |      INFO  | +15    | Main - "Adventure Island 3 (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Started
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).7z
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).7z
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).rar
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).rar
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).zip
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).zip
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).sfc
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).sfc
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).gba
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).gba
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).a78
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).a78
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).sv
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).sv
07:57:07:298 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).gbc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).gbc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).rpk
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).rpk
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).gme
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).gme
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).sc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).sc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).cdt
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).cdt
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).ws
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).ws
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).wsc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).wsc
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).ngp
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).ngp
07:57:07:299 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).ngc
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).ngc
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).vms
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).vms
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).ipf
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).ipf
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).n64
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).n64
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).z64
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).z64
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).sg
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).sg
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).fds
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).fds
07:57:07:300 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).caq
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).caq
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).vb
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).vb
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).vec
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).vec
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).wav
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).wav
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).cas
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).cas
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).min
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).min
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).int
07:57:07:301 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).int
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).rom
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).rom
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).tap
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).tap
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).tzx
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).tzx
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).nes
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).nes
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).col
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).col
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).nds
07:57:07:302 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).nds
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).cpr
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).cpr
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).gg
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).gg
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).pce
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).pce
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).st2
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).st2
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).sms
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).sms
07:57:07:303 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).smc
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).smc
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).lnx
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).lnx
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).md
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).md
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).32x
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).32x
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).n64
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).n64
07:57:07:304 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).a52
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).a52
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).j64
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).j64
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).cso
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).cso
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).cue
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).cue
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).iso
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).iso
07:57:07:305 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).ccd
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).ccd
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Rom not found
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).chd
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).chd
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).bin
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA)\Adventure Island 3 (USA).bin
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Looking for rom: I:\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).7z
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Found rom: I:\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).7z
07:57:07:306 | RL |      INFO  | +0     | CheckPaths - Ended
07:57:07:307 | RL |      INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					MiscUtils.DetectHiddenWindows("On")
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 12
					rlPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher
					pluginPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.1.1.1
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\HyperSpin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = C
					exitEmulatorKey = ~Esc
					restoreFE = false
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.exe
					emuPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch
					emuName = RetroArch
					emuExt = exe
					baseRomPath =
					romPath = I:\Arcade\Games\Nintendo Entertainment System\ROMS
					romPathFromIni = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Nintendo Entertainment System\ROMS|I:\Arcade\Games\Nintendo Entertainment System\ROMS
					romExtension = .7z
					romExtensionOrig = .7z
					romExtensions = 7z|rar|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin
					executable = retroarch.exe
					systemDbName = Nintendo Entertainment System
					systemName = Nintendo Entertainment System
					dbPath =
					dbName = Adventure Island 3 (USA)
					dbExt =
					romName = Adventure Island 3 (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					setResolution =
					logFile =
					logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
					logLevel = 3
					logShowDebugConsole = false
					logShowCommandWindow = true
					logCommandWindow = false
					logIncludeModule = true
					logIncludeDLLLogs = false
					errorSounds = true
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1920
					originalHeight = 1080
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdDriveLetterScsi =
					vdAddDrive = true
					demulShooterPath =
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					winIPACFullPath =
					ultraMapEnabled = false
					ultraMapFullPath =
					emuIdleShutdown = 0
					hideCursor = false
					hideEmu = false
					hideFE = false
					suspendFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeSounds = true
					fade7zProgressMode = extraction
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeProgressDuration = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoDeveloper = text with label
					fadeRomInfoPublisher = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher
					fadeRomInfoTextMargin = 7
					fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Media\Fade
					RLDataPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Data
					RLMediaPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Media
					RLErrSoundPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Media\Sounds\Error
					modulesPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Modules
					moduleFullName = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Modules\RetroArch\RetroArch.ahk
					moduleName = RetroArch
					modulePath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Modules\RetroArch
					moduleExtension = ahk
					moduleExtensionsPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions
					libPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Lib
					sevenZEnabled = false
					sevenZPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\7z.exe
					sevenZDllPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\7z.dll
					sevenZExtractPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Cache
					sevenZExtractPathOrig =
					sevenZAttachSystemName = false
					sevenZDelTemp = true
					sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
					sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
					sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
					7zExtractPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Games\Cache
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F3 down}{F3 up}|{Shift down}{2 down}{2 up}{Shift up}{F3 down}{F3 up}|{Shift down}{3 down}{3 up}{Shift up}{F3 down}{F3 up}|{Shift down}{4 down}{4 up}{Shift up}{F3 down}{F3 up}|{Shift down}{5 down}{5 up}{Shift up}{F3 down}{F3 up}|{Shift down}{6 down}{6 up}{Shift up}{F3 down}{F3 up}|{Shift down}{7 down}{7 up}{Shift up}{F3 down}{F3 up}|{Shift down}{8 down}{8 up}{Shift up}{F3 down}{F3 up}|{Shift down}{9 down}{9 up}{Shift up}{F3 down}{F3 up}|{Shift down}{10 down}{10 up}{Shift up}{F3 down}{F3 up}
					pauseLoadStateKeyCodes = {Shift down}{1 down}{1 up}{Shift up}{F4 down}{F4 up}|{Shift down}{2 down}{2 up}{Shift up}{F4 down}{F4 up}|{Shift down}{3 down}{3 up}{Shift up}{F4 down}{F4 up}|{Shift down}{4 down}{4 up}{Shift up}{F4 down}{F4 up}|{Shift down}{5 down}{5 up}{Shift up}{F4 down}{F4 up}|{Shift down}{6 down}{6 up}{Shift up}{F4 down}{F4 up}|{Shift down}{7 down}{7 up}{Shift up}{F4 down}{F4 up}|{Shift down}{8 down}{8 up}{Shift up}{F4 down}{F4 up}|{Shift down}{9 down}{9 up}{Shift up}{F4 down}{F4 up}|{Shift down}{10 down}{10 up}{Shift up}{F4 down}{F4 up}
					keyboardEncoder =
					keyboardEncoderEnabled = false
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Utilities\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Utilities\JoyToKey\JoyToKey.exe
					profilePath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles
					keymapperProfilePath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal =
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System
					xPadderSystemProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\_Default
					emuProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\RetroArch
					romProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\Adventure Island 3 (USA)
					RocketLauncherProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\Nintendo Entertainment System
					ahkEmuProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\RetroArch
					ahkRomProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\Adventure Island 3 (USA)
					ahkRocketLauncherProfile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					shaderName = false
					shaderColor =
					shaderTransparency =
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					qResFullPath = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\QRes.exe
					mon1O =
					pacDrivedllFile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Lib\User Fade Animations.ini
					testFile =
					testDuration =
					initialErrorMode = 0
07:57:07:312 | RL |      INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
07:57:07:312 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
07:57:07:312 | RL |   WARNING  | +0     | BuildScript - "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Lib\User Functions Init.ahk" not found
07:57:07:312 | RL |      INFO  | +0     | BuildScript - Validating module
07:57:07:316 | RL |      INFO  | +0     | BuildScript - Validation complete
07:57:07:316 | RL |      INFO  | +0     | BuildScript - Module:
					MEmu = RetroArch
					MEmuV =  v05-11-2015 Nightly
					MURL = http://themaister.net/retroarch.html
					MAuthor = djvj,zerojay
					MVersion = 2.4.2
					MCRC = A8D5F162
					iCRC = F7B77133
					MID = 635038268922229162
					MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
					; Notes:
					; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working!
					; Devs stated they will never add support for mounted images (like via DT)
					; Fullscreen is controlled via the module setting in RocketLauncherUI
					; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe).
					; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect
					; Enable 7z support for archived roms
					; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1
					; LibRetro DLLs:
					; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/
					; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system.
					; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores
					; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270
					; SRM files:
					; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm
					; Save states:
					; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save
					; Config files:
					; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI.
					; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg).
					; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg
					; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg.
					; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config.
					; MultiGame:
					; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch.
					; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind.
					; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12.
					; MAME:
					; MAME BIOS roms should be placed in the system\mame folder
					; System Specific Notes:
					; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine.
					; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these.
					; NEC TurboGrafx-CD (using pce fast core) - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg.
					; NEC TurboGrafx-CD (using MAME core)
					;   - You'll need to update a couple mame specific options in the Retroarch core options file to get it to boot from the cli. These should probably be updated automagically by the module. Turning softlists off, but might not need to.
					;       mame_boot_from_cli = "enabled"
					;       mame_softlists_enable = "disabled"
					;       mame_softlists_auto_media = "disabled"
					;	- Requires hash folder from MAME/MESS/UME, either from the source or release package. Save this in the system_directory you've defined for RetroArch. Something like \RetroArch\system\mame\hash\
					;	- Requires the CD bios file(s) saved in the mame bios folder you've defined. Usually \RetroArch\system\mame\bios\
					;		For PC Engine-CD you'll need the file "[cd] cd-rom system (japan) (v2.1).pce" zipped as cdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\cdsys.zip
					;		For PC Engine SuperGrafx-CD you'll need the file "[cd] super cd-rom system (japan) (v3.0).pce" zipped as scdsys.zip and saved in a pce subfolder in your bios path, so \RetroArch\system\mame\bios\pce\scdsys.zip
					;		For TurboGrafx-CD you'll need the file "[cd] turbografx cd system card (usa) (v2.0).pce" zipped as cdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\cdsys.zip
					;		For TurboDuo you'll need the file "[cd] turbografx cd super system card (usa) (v3.0).pce" zipped as scdsys.zip and saved in a tg16 subfolder in your bios path, so \RetroArch\system\mame\bios\tg16\scdsys.zip
					; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode.
					; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files.
					; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory.
					StartModule()
					BezelGUI()
					FadeInStart()
					primaryExe := new Emulator(emuPath . "\" . executable)	; instantiate emulator executable object
					emuPrimaryWindow := new Window(new WindowTitle("RetroArch","RetroArch"))	; instantiate primary emulator window object
					emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass"))	; instantiate emulator console window object
					; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
					; 1 - Official System Name in RocketLauncher
					; 2 - Short name used only for easy referencing within module
					; 3 - Default core
					; 4 - The system ID MAME core recognizes
					RLLog.Debug("Module - Started building the " . MEmu . " object")
					mTypeVar:="
						( LTrim
						AAE|LibRetro_AAE|mame_libretro
						Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb
						Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464
						Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000
						APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag
						Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs
						Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic
						Atari 2600|LibRetro_2600|stella_libretro|a2600
						Atari 5200|LibRetro_5200|mess_libretro|a5200
						Atari 7800|LibRetro_7800|prosystem_libretro|a7800
						Atari 8-Bit|LibRetro_ATARI8|mess_libretro|a800
						Atari Classics|LibRetro_ACLS|mame_libretro
						Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar
						Atari Lynx|LibRetro_LYNX|handy_libretro|lynx
						Atari ST|LibRetro_ST|hatari_libretro
						Atari XEGS|LibRetro_XEGS|mess_libretro|xegs
						Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde
						Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78
						Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000
						Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan
						Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor
						Canon X07|LibRetro_CX07|mess_libretro|x07
						Capcom Classics|LibRetro_CAPC|mame_libretro
						Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro
						Capcom Play System II|LibRetro_CPS2|fba_cores_cps2_libretro
						Capcom Play System III|LibRetro_CPS3|mame_libretro
						Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000
						Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000
						Cave|LibRetro_CAVE|mame_libretro
						Coleco ADAM|LibRetro_ADAM|mess_libretro|adam
						ColecoVision|LibRetro_COLEC|mess_libretro|coleco
						Commodore Amiga|LibRetro_PUAE|puae_libretro
						Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10
						Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck
						Data East Classics|LibRetro_DATA|mame_libretro
						Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64
						Elektronika BK|LibRetro_EBK|mess_libretro|bk0010
						Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64
						Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia
						Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision
						Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock
						Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv
						Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer
						Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf
						Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro
						Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan
						GamePark 32|LibRetro_GP32|mess_libretro|gp32
						GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex
						Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster
						Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000
						Irem Classics|LibRetro_IREM|mame_libretro
						JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii
						Konami Classics|LibRetro_KONC|mame_libretro
						Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2
						MAME|LibRetro_MAME|mame_libretro|mame
						Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32
						Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius
						Mattel Intellivision|LibRetro_INTV|mess_libretro|intv
						MGT Sam Coupe|LibRetro_SAMCP|mess_libretro|
						Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro
						Microsoft MSX|LibRetro_MSX|bluemsx_libretro
						Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro
						Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro
						Midway Classics|LibRetro_MIDC|mame_libretro
						Namco Classics|LibRetro_NAMC|mame_libretro
						Namco System 22|LibRetro_NAM2|mame_libretro
						NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce,cart
						NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce,cdrom
						NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro
						NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx,cart
						NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16,cart
						NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16,cdrom
						Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64
						Nintendo 64DD|LibRetro_N64|mupen64plus_libretro
						Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro
						Nintendo Classics|LibRetro_NINC|mame_libretro
						Nintendo DS|LibRetro_DS|desmume_libretro
						Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes
						Nintendo Famicom|LibRetro_NFAM|nestopia_libretro
						Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom
						Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy
						Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba
						Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor
						Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy
						Nintendo Game & Watch|LibRetro_GW|gw_libretro
						Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini
						Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro
						Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro
						Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro
						Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro
						Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy
						Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro
						Panasonic 3DO|LibRetro_3DO|4do_libretro
						Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1
						Philips Videopac|LibRetro_PVID|mess_libretro|videopac
						RCA Studio II|LibRetro_STUD2|mess_libretro|studio2
						SCUMMVM|LibRetro_SCUMM|scummvm_libretro
						Sega 32X|LibRetro_32X|picodrive_libretro|32x
						Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd
						Sega Classics|LibRetro_SEGC|mame_libretro
						Sega Dreamcast|LibRetro_DCAST|reicast_libretro
						Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear
						Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis
						Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro
						Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms
						Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv
						Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro
						Sega Meganet|LibRetro_GEN|genesis_plus_gx_libretro|genesis
						Sega Nomad|LibRetro_GEN|genesis_plus_gx_libretro|genesis
						Sega Pico|LibRetro_PICO|picodrive_libretro
						Sega Saturn|LibRetro_SAT|yabause_libretro|saturn
						Sega Saturn Japan|LibRetro_SAT|yabause_libretro|saturnjp
						Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000
						Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro
						Sega ST-V|LibRetro_STV|mame_libretro
						Sega VMU|LibRetro_SVMU|mess_libretro|svmu
						Sharp X1|LibRetro_SX1|mess_libretro|x1
						Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum
						SNK Classics|LibRetro_SNKC|mame_libretro
						SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro
						SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes
						SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz
						SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro
						SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp
						SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc
						Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psu
						Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro
						Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat
						Sony PSP|LibRetro_PSP|ppsspp_libretro
						Sony PSP Minis|LibRetro_PSP|ppsspp_libretro
						Sord M5|LibRetro_SORD|mess_libretro|m5
						Spectravideo|LibRetro_SV328|mess_libretro|svi328n
						Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes
						Taito Classics|LibRetro_TAIC|mame_libretro
						Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3
						Technos|LibRetro_TECHN|mame_libretro
						Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a
						Thomson MO5|LibRetro_MO5|mess_libretro|mo5
						Thomson TO7|LibRetro_TO7|mess_libretro|to7
						Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom
						Tiki-100|LibRetro_TIKI|mess_libretro|kontiki
						Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor
						VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision
						Watara Supervision|LibRetro_SUPRV|mess_libretro|svision
						Williams Classics|LibRetro_WILLS|mame_libretro
					mType := Object()
					Loop, Parse, mTypeVar, `n, `r
						obj := {}
						Loop, Parse, A_LoopField, |
							If (A_Index = 1)
								obj.System := A_LoopField
							Else If (A_Index = 2)
								obj.ID := A_LoopField
							Else If (A_Index = 3)
								obj.Core := A_LoopField
							Else {	; 4
								StringSplit, tmp, A_LoopField, `,
								obj.MAMEID := tmp1
								obj.MAMEMedia := tmp2
						mType.Insert(obj["System"], obj)
					RLLog.Debug("Module - Finished building the " . MEmu . " object")
					; For easier use throughout the module
					retroSystem := mType[systemName].System
					retroID := mType[systemName].ID
					retroCore := mType[systemName].Core
					retroMAMEID := mType[systemName].MAMEID
					retroMAMEMedia := mType[systemName].MAMEMedia
					RLLog.Info("Module - Using these system variables:")
					RLLog.Info("Module - retroSystem: " . retroSystem)
					RLLog.Info("Module - retroID: " . retroID)
					RLLog.Info("Module - retroCore: " . retroCore)
					RLLog.Info("Module - retroMAMEID: " . retroMAMEID)
					RLLog.Info("Module - retroMAMEMedia: " . retroMAMEMedia)
					If !retroSystem
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName)
					If !retroCore
						ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")
					Fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1)
					configFolder := moduleIni.Read("Settings", "ConfigFolder",emuPath . "\config","",1)
					mameRomPath := moduleIni.Read("MAME", "BIOS_Roms_Folder","","",1)
					mameHideNag := If moduleIni.Read("MAME", "Hide_Nag_Screen","false","",1) = "true" ? "enabled" : "disabled"
					mameHideInfo := If moduleIni.Read("MAME", "Hide_Info_Screen","false","",1) = "true" ? "enabled" : "disabled"
					mameHideWarn := If moduleIni.Read("MAME", "Hide_Warning_Screen","false","",1) = "true" ? "enabled" : "disabled"
					hideConsole := moduleIni.Read("Settings", "HideConsole","true","",1)
					ejectToggleKey := moduleIni.Read("Settings", "Eject_Toggle_Key","","",1)
					nextDiskKey := moduleIni.Read("Settings", "Next_Disk_Key","","",1)
					prevDiskKey := moduleIni.Read("Settings", "Previous_Disk_Key","","",1)
					core := moduleIni.Read(romName . "|" . systemName, "LibRetro_Core",retroCore,"",1)
					superGB := moduleIni.Read(romName . "|" . systemName, "SuperGameBoy","false","",1)
					enableNetworkPlay := moduleIni.Read(romName . "|Network", "Enable_Network_Play","false","",1)
					overlay := moduleIni.Read(romName . "|" . systemName, "Overlay","","",1)
					videoShader := moduleIni.Read(romName . "|" . systemName, "VideoShader","","",1)
					aspectRatioIndex := moduleIni.Read(romName . "|" . systemName, "AspectRatioIndex","","",1)
					customViewportWidth := moduleIni.Read(romName . "|" . systemName, "CustomViewportWidth","","",1)
					customViewportHeight := moduleIni.Read(romName . "|" . systemName, "CustomViewportHeight","","",1)
					customViewportX := moduleIni.Read(romName . "|" . systemName, "CustomViewportX","","",1)
					customViewportY := moduleIni.Read(romName . "|" . systemName, "CustomViewportY","","",1)
					stretchToFillBezel := moduleIni.Read(romName . "|" . systemName, "StretchToFillBezel","false","",1)
					rotation := moduleIni.Read(romName . "|" . systemName, "Rotation",0,"",1)
					cropOverscan := moduleIni.Read(romName . "|" . systemName, "CropOverscan","","",1)
					threadedVideo := moduleIni.Read(romName . "|" . systemName, "ThreadedVideo","","",1)
					vSync := moduleIni.Read(romName . "|" . systemName, "VSync","","",1)
					integerScale := moduleIni.Read(romName . "|" . systemName, "IntegerScale","","",1)
					configurationPerCore := moduleIni.Read(romName . "|" . systemName, "ConfigurationPerCore","false","",1)
					If (StringUtils.Contains(core, "^(mame|mess|ume)") && !retroMAMEID) {
						retroMAMEID := "mame"	; set all systems that use a mame core to the default mame ID so any system name is supported
						RLLog.Warning("Module - Setting MAMEID to default ""mame"" for """ . retroSystem . """")
					configFolder := RLObject.getFullPathFromRelative(rlPath,configFolder)
					mameRomPath := If mameRomPath ? RLObject.getFullPathFromRelative(rlPath,mameRomPath) : romPath
					overlay := RLObject.getFullPathFromRelative(rlPath,overlay)
					videoShader := RLObject.getFullPathFromRelative(rlPath,videoShader)
					rotateBezel := false
					configFolder := new Folder(configFolder)
					If (retroID = "LibRetro_SGB" || superGB = "true")	; if system or rom is set to use Super Game Boy
					{	superGB := "true"	; setting this just in case it's false and the system is Nintendo Super Game Boy
						sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system")
						CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system")
						retroID := "LibRetro_SGB"	; switching to Super Game Boy mode
						retroSystem := "Nintendo Super Game Boy"
					; Find the dll for this system
					libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")
					; Find the cfg file to use
					If !configFolder.Exist()
						ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder.FilePath . """")
					globalRetroCfg := emuPath . "\retroarch.cfg"
					systemRetroCfg := configFolder.FilePath . "\" . retroSystem . ".cfg"
					coreRetroCfg := configFolder.FilePath . "\" . core . ".dll.cfg"
					RLLog.Info("Module - Global cfg should be: " . globalRetroCfg)
					RLLog.Info("Module - System cfg should be: " . systemRetroCfg)
					RLLog.Info("Module - Core cfg should be: " . coreRetroCfg)
					foundCfg := ""
					systemRetroCfg := new File(systemRetroCfg)
					coreRetroCfg := new File(coreRetroCfg)
					globalRetroCfg := new File(globalRetroCfg)
					If systemRetroCfg.Exist() {	; check for system cfg first
						retroCFGFile := systemRetroCfg
						foundCfg := 1
						RLLog.Info("Module - Found a System cfg!")
					} Else If coreRetroCfg.Exist() {	; 2nd option is a core config
						retroCFGFile := coreRetroCfg
						foundCfg := 1
						RLLog.Info("Module - Found a Core cfg!")
					} Else If globalRetroCfg.Exist() {	; 3rd is global cfg
						retroCFGFile := globalRetroCfg
						foundCfg := 1
						RLLog.Info("Module - Found a Global cfg!")
					If foundCfg {
						RLLog.Info("Module - " . MEmu . " is using " . retroCFGFile.FileFullPath . " as its config file.")
						retroCFG := LoadProperties(retroCFGFile.FileFullPath)
					} Else
						RLLog.Warning("Module - Could not find a cfg file to update settings. RetroArch will make one for you.")
					If StringUtils.Contains(rotation,"1|3") ; use vertical bezel if RA rotation is set to 90 or 270 degrees
						rotateBezel := true
					If StringUtils.Contains(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") {		; these systems require the retroarch settings to be read
						retroSysDir := ReadProperty(retroCFG,"system_directory")	; read value
						retroSysDir := ConvertRetroCFGKey(retroSysDir)	; remove dbl quotes
						retroSysDirLeft := StringUtils.Left(retroSysDir, 2)
						If (retroSysDirLeft = ":\") {	; if retroarch is set to use a default folder
							retroSysDir := StringUtils.TrimLeft(retroSysDir, 1)
							RLLog.Info("Module - RetroArch is using a relative system path: """ . retroSysDir . """")
							retroSysDir := emuPath . retroSysDir
						If !retroSysDir
							ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.")
						checkForSlash := StringUtils.Right(retroSysDir, 1)
						If (checkForSlash = "\")	; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders
							retroSysDir := StringUtils.TrimRight(retroSysDir, 1)
					If (StringUtils.Contains(core, "^(mame|mess|ume)")) || (StringUtils.Contains(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX")) || (StringUtils.Contains(retroID, "LibRetro_NES") && (StringUtils.Contains(core, "nestopia_libretro"))) {	; these systems will use an ini to store game specific settings
						RLLog.Info("Module - Reading / creating system ini for specific settings.")
						If !StringUtils.Contains(core, "^(mame|mess|ume)") {
							If !SystemModuleIni.Exist()
								SystemModuleIni.Append		; create a new blank ini file if one does not exist
						If (configurationPerCore = "true") {
							coreOptionsCFGFile := new File(configFolder.FilePath . "\retroarch-core-options.cfg")
							coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . configFolder.FilePath . """")
						} Else {
							coreOptionsCFGFile := new File(emuPath . "\retroarch-core-options.cfg")
							coreOptionsCFGFile.CheckFile("Could not find retroarch-core-options.cfg in retroarch directory: """ . emuPath . """")
						coreOptionsCFG := LoadProperties(coreOptionsCFGFile.FileFullPath)
						If StringUtils.Contains(core, "^(mame|mess|ume)") {	; Set some MAME/MESS/UME core options.
							tmpCore := If StringUtils.Contains(core, "mame") ? "mame" : "mess"
							WriteProperty(coreOptionsCFG, tmpCore . "_read_config", """enabled""", 1)
							WriteProperty(coreOptionsCFG, tmpCore . "_boot_from_cli", """enabled""", 1)				; This needs to be enabled in order to run games with RLauncher
							WriteProperty(coreOptionsCFG, tmpCore . "_hide_nagscreen", "" . mameHideNag . "", 1)
							WriteProperty(coreOptionsCFG, tmpCore . "_hide_infoscreen", "" . mameHideInfo . "", 1)
							WriteProperty(coreOptionsCFG, tmpCore . "_hide_warnings", "" . mameHideWarn . "", 1)
						} Else If StringUtils.Contains(retroID, "LibRetro_N64") {	; Nintendo 64
							mupenGfx := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Plugin", "auto","",1)
							mupenRsp := moduleIni.Read(romName . "|" . systemName, "Mupen_RSP_Plugin", "auto","",1)
							mupenCpu := moduleIni.Read(romName . "|" . systemName, "Mupen_CPU_Core", "dynamic_recompiler","",1)
							mupenPak1 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_1", "memory","",1)
							mupenPak2 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_2", "memory","",1)
							mupenPak3 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_3", "memory","",1)
							mupenPak4 := moduleIni.Read(romName . "|" . systemName, "Mupen_Pak_4", "memory","",1)
							mupenGfxAccur := moduleIni.Read(romName . "|" . systemName, "Mupen_Gfx_Accuracy", "high","",1)
							mupenExpMem := moduleIni.Read(romName . "|" . systemName, "Mupen_Disable_Exp_Memory", "no","",1)
							mupenTexturFilt := moduleIni.Read(romName . "|" . systemName, "Mupen_Texture_Filtering", "nearest","",1)
							mupenViRefresh := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Refresh", "2200","",1)
							mupenFramerate := moduleIni.Read(romName . "|" . systemName, "Mupen_Framerate", "fullspeed","",1)
							mupenResolution := moduleIni.Read(romName . "|" . systemName, "Mupen_Resolution", "640x480","",1)
							mupenPolyOffstFctr := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Factor", "-3.0","",1)
							mupenPolyOffstUnts := moduleIni.Read(romName . "|" . systemName, "Mupen_Polygon_Offset_Units", "-3.0","",1)
							mupenViOverlay := moduleIni.Read(romName . "|" . systemName, "Mupen_VI_Overlay", "disabled","",1)
							mupenAnalogDzone := moduleIni.Read(romName . "|" . systemName, "Mupen_Analog_Deadzone", "15","",1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1)
							WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1)
							WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1)
							WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1)
							WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1)
							WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1)
							WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1)
							WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1)
							WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1)
							WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1)
						} Else If StringUtils.Contains(retroID, "LibRetro_NES") {		; these systems will use an ini to store game specific settings
							If StringUtils.Contains(core, "nestopia_libretro") {	; Nestopia
								nestopiaBlargg := moduleIni.Read(romName . "|Nestopia", "Nestopia_Blargg_NTSC_Filter", "disabled","",1)
								nestopiaPalette := moduleIni.Read(romName . "|Nestopia", "Nestopia_Palette", "canonical","",1)
								nestopiaNoSprteLimit := moduleIni.Read(romName . "|Nestopia", "Nestopia_Remove_Sprites_Limit", "disabled","",1)
								WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1)
								WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1)
								WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1)
						} Else If StringUtils.Contains(retroID, "LibRetro_LYNX") {	; Atari Lynx
							If StringUtils.Contains(core, "handy_libretro") {   ; Handy
								handyRotate := moduleIni.Read(romName . "|" . systemName, "Handy_Rotation", "None","",1)
								If StringUtils.Contains(handyRotate, "240") or StringUtils.Contains(handyRotate, "90")
									rotateBezel := true
								WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1)
						} Else If StringUtils.Contains(retroID, "LibRetro_PSX") {	; Sony PlayStation
							psxCdImageCache := moduleIni.Read(romName . "|" . systemName, "PSX_CD_Image_Cache", """enabled""","",1)
							psxMemcardHandling := moduleIni.Read(romName . "|" . systemName, "PSX_Memcard_Handling", """libretro""","",1)
							psxDualshockAnalogToggle := moduleIni.Read(romName . "|" . systemName, "PSX_Dualshock_Analog_Toggle", """enabled""","",1)
							WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1)
						SaveProperties(coreOptionsCFGFile.FileFullPath, coreOptionsCFG)
					hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1)
					7z(romPath, romName, romExtension, sevenZExtractPath)
					mgM3UFile := new File(romPath . "\" . romTable[1,4] . ".m3u")
					mgRomExtensions := "cue|iso|ccd"
					mgValidExtension := false
					Loop, Parse, mgRomExtensions, |
						If (romExtension = "." . A_LoopField)
							mgValidExtension := true
					If (StringUtils.Contains(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated
						m3uRomIndex := Object()
						mgType := romTable[1,6] . " "
						mgMaxIndex := romTable.MaxIndex()
						mgRomIndex := 0
						If mgM3UFile.Exist()
							mgM3UFile.Delete()
						Loop % mgMaxIndex
							If (romTable[A_Index, 3] = romName) {
								tempType := romTable[A_Index, 5]
								mgRomIndex := StringUtils.TrimLeft(tempType, StringUtils.StringLength(mgType))
								RLLog.Info("Found rom index in rom set in romTable: " . mgRomIndex)
								Break
						If (mgRomIndex > 0) {
							tempRomIndex := mgRomIndex
							Loop % mgMaxIndex
								mgTypeIndex := mgType . tempRomIndex
								m3uRomIndex.Insert(tempRomIndex)
								Loop % mgMaxIndex
									If (romTable[A_Index, 5] = mgTypeIndex) {
										tempRomPath := romTable[A_Index, 1]
										mgM3UFile.Append(tempRomPath . "`n")
										RLLog.Info("Module - Appending rom path to m3u: " . tempRomPath)
										Break
								If (tempRomIndex < mgMaxIndex)
									tempRomIndex++
								Else
									tempRomIndex := 1
					; MAME/MESS/UME core options
					MAMEParam1 := ""
					MAMEParam2 := ""
					MAMEParam3 := ""
					If StringUtils.Contains(core, "^(mame|mess|ume)") {	; if a MAME/MESS/UME core is used
						If !retroMAMEID
							ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MAME/MESS/UME LibRetro core")
						Else
							RLLog.Info("Module - MAME/MESS/UME mode using a known ident: " . retroMAMEID)
						If !mameRomPath
							ScriptError("Please set the RetroArch module setting ""BIOS_Roms_Folder"" to the folder that contains your MAME/MESS/UME BIOS roms to use with RetroArch.")
						If (retroMAMEID = "mame") {		; want this for arcade mame only
							RLLog.Info("Module - Retroarch MAME/MESS/UME Arcade mode enabled")
							fullRomPath := " """ . romPath . "\" . romName . romExtension . """"
						} Else {
							RLLog.Info("Module - Retroarch MAME/MESS/UME Console/PC mode enabled")
							MAMEParam1 := ""
							MAMEParam2 := " -rompath \""" . mameRomPath . "\"""
							; If we already have a media type, then use it.
							If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cart") {
								;MAMEParam3 := " -cart \" . """" . romPath . "\" . romName . romExtension . "\" . """"
								MAMEParam3 := " -cart \""" . romPath . "\" . romName . romExtension . "\"""""
							; TODO: This needs a better way to handle the cdrom bios files, in my opinion. As it is, there's no clean way to pick between the v2.00 or v3.00 bios.
							;       Defaulting to the TurboDuo cdrom bios since it will play 2.00 or 3.00 games.
							} Else If (StringUtils.Contains(retroMAMEID, "tg16|pce") && retroMAMEMedia = "cdrom") {
								;MAMEParam3 := " -cart cdsys -cdrm \" . """" . romPath . "\" . romName . romExtension . "\" . """"
								MAMEParam3 := " -cart scdsys -cdrm \""" . romPath . "\" . romName . romExtension . "\"""""
							} Else {
								; Build a key/value object containing the different MAMEParam3 choices
								MAMEP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","saturn","cdrm","saturnjp","cdrm","svi328n","cass","pecom64","cass","psu","cdrm","svmu","quik","gamecom","cart1","mbeeic","quik1")
								MAMEParam3 := MAMEP3[retroMAMEID]	; search object for the retroMAMEID pair
								MAMEParam3 := " -" . (If MAMEParam3 ? MAMEParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
							If (retroMAMEID = "mbeeic") ; Applied Technology MicroBee
							{	microbeeModel := IniReadCheck(MAMESysINI, romName, "MicroBee_Model","mbeeic","",1)
								If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
									ScriptError("This is not a known MicroBee model value: " . microbeeModel)
								Else If (microbeeModel != "mbeeic")
									retroMAMEID := microbeeModel
								If romExtension in .mwb,.com,.bee
									mediaDeviceType := "quik1"
								Else If romExtension in .wav,.tap
									mediaDeviceType := "cass"
								Else If romExtension in .rom
									mediaDeviceType := "cart"
								Else If romExtension in .dsk
									mediaDeviceType := "flop1"
								Else	; .bin format
									mediaDeviceType := "quik2"
								MAMEParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
							fullRomPath := MAMEParam1 . MAMEParam2 . MAMEParam3
					} Else If (superGB = "true") {
						RLLog.Info("Module - Retroarch Super Game Boy mode enabled")
						fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """"
					} Else {
						RLLog.Info("Module - Retroarch standard mode enabled")
					If (retroID = "LibRetro_NFDS")	; Nintendo Famicom Disk System
					{	disksysRom := new File(retroSysDir . "\disksys.rom")
						If !disksysRom.Exist()
							ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If (retroID = "LibRetro_SCD")	; Sega CD
					{	If !StringUtils.Contains(romExtension, "\.bin|\.cue|\.iso")
							ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension)
						biosCDEBin := new File(retroSysDir . "\bios_CD_E.bin")
						biosCDUBin := new File(retroSysDir . "\bios_CD_U.bin")
						biosCDJBin := new File(retroSysDir . "\bios_CD_J.bin")
						If !biosCDEBin.Exist()
							ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						If !biosCDUBin.Exist()
							ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						If !biosCDJBin.Exist()
							ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If StringUtils.Contains(retroID,"LibRetro_PCECD|LibRetro_TGCD")	; NEC PC Engine-CD and NEC TurboGrafx-CD
					{	If !StringUtils.Contains(romExtension,"\.ccd|\.cue")
							ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension)
						sysCard3Pce := new File(retroSysDir . "\syscard3.pce")
						If !sysCard3Pce.Exist()
							ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If (retroID = "LibRetro_PCFX")
						pcfxBios := new File(retroSysDir . "\pcfx.bios")
						If !pcfxBios.Exist()
							ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If (retroID = "LibRetro_SCUMM")
						scummFile := new File(romPath . "\" . romName . ".scummvm")
						If !scummFile.Exist()
							scummFile.Append("""" . romName . """")
					networkSession := ""
					If (enableNetworkPlay = "true") {
						RLLog.Info("Module - Network Multi-Player is an available option for " . dbName)
						netplayNickname := moduleIni.Read("Network", "NetPlay_Nickname","Player","",1)
						getWANIP := moduleIni.Read("Network", "Get_WAN_IP","false","",1)
						If (getWANIP = "true")
							myPublicIP := GetPublicIP()
						RLLog.Warning("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE")
						defaultServerIP := moduleIni.Read("Network", "Default_Server_IP", myPublicIP,"",1)
						defaultServerPort := moduleIni.Read("Network", "Default_Server_Port","","",1)
						lastIP := moduleIni.Read("Network", "Last_IP", defaultServerIP,"",1)	; does not need to be on the ISD
						lastPort := moduleIni.Read("Network", "Last_Port", defaultServerPort,"",1)	; does not need to be on the ISD
						mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,"",0)
						If (mpMenuStatus = -1) {	; if user exited menu early
							RLLog.Warning("Module - Cancelled MultiPlayer Menu. Exiting module.")
							ExitModule()
						If networkSession {
							RLLog.Info("Module - Using a Network for " . dbName)
							moduleIni.Write(networkPort, "GlobalModuleIni", "Network", "Last_Port")
							; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort%
							If (networkType = "client") {
								moduleIni.Write(networkIP, "GlobalModuleIni", "Network", "Last_IP")	; Save last used IP and Port for quicker launching next time
								netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """"	; -C = connect as client
							} Else {	; server
								netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """"	; -H = host as server
							RLLog.Info("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """")
						} Else
							RLLog.Info("Module - User chose Single Player mode for this session")
					BezelStart(,,(If rotateBezel ? 1:""))
					If foundCfg {
						If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath)
							customViewportWidth := bezelScreenWidth
							customViewportHeight := bezelScreenHeight
							customViewportX := 0
							customViewportY := 0
							aspectRatioIndex := 22
							RLLog.Info("Stretching viewport to fit bezel")
						raCfgHasChanges := ""
						WriteRetroProperty("input_overlay", overlay)
						WriteRetroProperty("video_shader", videoShader)
						WriteRetroProperty("aspect_ratio_index", aspectRatioIndex)
						WriteRetroProperty("custom_viewport_width", customViewportWidth)
						WriteRetroProperty("custom_viewport_height", customViewportHeight)
						WriteRetroProperty("custom_viewport_x", customViewportX)
						WriteRetroProperty("custom_viewport_y", customViewportY)
						WriteRetroProperty("video_rotation", rotation)
						WriteRetroProperty("video_crop_overscan", cropOverscan)
						WriteRetroProperty("video_threaded", threadedVideo)
						WriteRetroProperty("video_vsync", vSync)
						WriteRetroProperty("video_scale_integer", integerScale)
						WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey)
						WriteRetroProperty("input_disk_next", nextDiskKey)
						WriteRetroProperty("input_disk_prev", prevDiskKey)
							Loop, 8	; Loop 8 times for 8 controllers
							{	p%A_Index%ControllerType := moduleIni.Read(romName . "|" . systemName, "P" . A_Index . "_Controller_Type", 517,"",1)
								WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType)
						If raCfgHasChanges {
							RLLog.Info("Module - Saving changed settings to: """ . retroCFGFile.FileFullPath . """")
							SaveProperties(retroCFGFile.FileFullPath, retroCFG)
					fullscreen := If fullscreen = "true" ? " -f" : ""
					srmPath := new Folder(emuPath . "\srm\" . retroSystem)	; path for this system's srm files
					saveStatePath := new Folder(emuPath . "\save\" . retroSystem)	; path for this system's save state files
					retroCFGFileCLI := If foundCfg ? " -c """ . retroCFGFile.FileFullPath . """" : ""
					If !srmPath.Exist("folder")
						srmPath.CreateDir() ; creating srm dir if it doesn't exist
					If !saveStatePath.Exist("folder")
						saveStatePath.CreateDir() ; creating save dir if it doesn't exist
					HideAppStart(hideEmuObj,hideEmu)
					If (StringUtils.Contains(core, "^(mame|mess|ume)") && (retroMAMEID != "mame")) {    ; if a MAME/MESS/UME core is used
						primaryExe.Run(" """ . (retroMAMEID ? retroMAMEID : "") . fullRomPath . """ " . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
					} Else If (retroID = "LibRetro_SCUMM") {
						primaryExe.Run(" """ . scummFile . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
					} Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case.
						primaryExe.Run(fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . fullRomPath . netCommand, "Hide")
					} Else If mgM3UFile.Exist() {
						primaryExe.Run(" """ . mgM3UFile.FileFullPath . """" . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
					} Else {
						primaryExe.Run(" " . fullRomPath . fullscreen . retroCFGFileCLI . " -L """ . libDll . """ -s """ . srmPath.FilePath . "\" . romName . ".srm"" -S """ . saveStatePath.FilePath . "\" . romName . ".state""" . netCommand, "Hide")
					mpMenuStatus := ""
					If networkSession {
						canceledServerWait := false
						multiplayerMenuExit := false
						TimerUtils.SetTimer("NetworkConnectedCheck", 500)
						If (networkType = "server") {
							RLLog.Info("Module - Waiting for a client to connect to your server")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.")
						} Else {	; client
							RLLog.Info("Module - Trying to contact the server to establish a connection.")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...")
						If (mpMenuStatus = -1) {	; if user exited menu early before a client connected
							RLLog.Warning("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.")
							If primaryExe.Process("Exist")
								primaryExe.Process("Close")	; must close process as the exe is waiting for a client to connect and no window was drawn yet
							ExitModule()
						} Else {	; blank response from MultiPlayerMenu, exited properly
							RLLog.Info("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server")
							emuPrimaryWindow.Wait()
							emuPrimaryWindow.WaitActive()
						TimerUtils.SetTimer("NetworkConnectedCheck", "Off")
					} Else {	; single player
					If (hideConsole = "true")
						emuConsoleWindow.Set("Transparent", "On")	; makes the console window transparent so you don't see it on exit
					BezelDraw()
					HideAppEnd(hideEmuObj,hideEmu)
					FadeInExit()
					primaryExe.Process("WaitClose")
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					; Writes new properties into the retroCFG if defined by user
					WriteRetroProperty(key,value="") {
						If (value != "") {
							Global retroCFG,raCfgHasChanges
							WriteProperty(retroCFG, key, value,1,1)
							raCfgHasChanges := 1
					; Used to convert between RetroArch keys and usable data
					ConvertRetroCFGKey(txt,direction="read"){
						Global emuPath,RLLog
						If (direction = "read")
						{	newtxt := StringUtils.TrimLeft(txt,1,0)	; removes the " from the left of the txt
							newtxt := StringUtils.TrimRight(newtxt,1,0)	; removes the " from the right of the txt
							relativeCheck := StringUtils.SubStr(newtxt,1,1,0)
							If StringUtils.Contains(relativeCheck,":",0) {	; if the path contains a ":" then it is a relative path
								RLLog.Debug("ConvertRetroCFGKey - " . newtxt . " is a relative path")
								newtxt := StringUtils.TrimLeft(newtxt,1,0)	; removes the : from the left of the txt
								newtxt := AbsoluteFromRelative(emuPath, "." . newtxt)	; convert relative to absolute
							If StringUtils.Contains(newtxt,"/",0)
								newtxt := StringUtils.Replace(newtxt,"/","\",1,"",0)	; replaces all forward slashes with backslashes
						} Else If (direction = "write")
						{	newtxt := """" . txt . """"	; wraps the txt with ""
							If StringUtils.Contains(newtxt,"\\",0)
								newtxt := StringUtils.Replace(newtxt,"\","/",1,"",0)	; replaces all backslashes with forward slashes
						} Else
							ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.")
						RLLog.Debug("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt)
						Return newtxt
					MultiGame:
						KeyUtils.SetKeyDelay(100)
						emuPrimaryWindow.Activate()
						KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}")	; eject disc in Retroarch
						If (!mgLastRomIndex) {
							mgLastRomIndex := mgRomIndex
						selectedRomIndex := 0
						selectedRomIndex := StringUtils.TrimLeft(selectedRomNum, StringUtils.StringLength(mgType,0))
						Loop % mgMaxIndex
							If (m3uRomIndex[A_index] = mgLastRomIndex) {
								tempLastRomIndex := A_index
								RLLog.Debug("Module - Last index: " . tempLastRomIndex)
							If (m3uRomIndex[A_index] = selectedRomIndex) {
								tempSelectedRomIndex := A_index
								RLLog.Debug("Module - Selected index: " . tempSelectedRomIndex)
						mgNewIndex := tempLastRomIndex - tempSelectedRomIndex
						If (mgNewIndex < 0) {
							mgNewIndex := mgNewIndex * -1
							Loop % mgNewIndex
								RLLog.Debug("Module - Sending the next disk key: " . nextDiskKey)
								KeyUtils.Send("{" . nextDiskKey . " down}{" . nextDiskKey . " up}")
						} Else If (mgNewIndex > 0) {
							Loop % mgNewIndex
								RLLog.Debug("Module - Sending the previous disk key: " . mgNewIndex)
								KeyUtils.Send("{" . prevDiskKey . " down}{" . prevDiskKey . " up}")
						KeyUtils.Send("{" . ejectToggleKey . " down}{" . ejectToggleKey . " up}")	; close disc in Retroarch
						mgLastRomIndex := selectedRomIndex
					Return
					NetworkConnectedCheck:
						If clientConnected
							multiplayerMenuExit := true
						Else If emuPrimaryWindow.Exist() {
							RLLog.Info("Module - RetroArch session started, closing the MultiPlayer menu")
					Return
					CloseProcess:
						FadeOutStart()
						emuPrimaryWindow.Close()
					Return
07:57:07:329 | RL |      INFO  | +15    | BuildScript - Loaded Multi-Player scripts
07:57:07:330 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
07:57:07:330 | RL |   WARNING  | +0     | BuildScript - "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\Lib\User Functions.ahk" not found
07:57:07:330 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
07:57:07:331 | RL |      INFO  | +0     | Main - Module is built
07:57:07:331 | RL |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\RocketLauncher\AutoHotkey.dll exists
07:57:07:334 | RL |      INFO  | +0     | Main - Running module
07:57:07:449 | MD |      INFO  | +N/A   | Module initialized
07:57:07:450 | MD |      INFO  | +0     | StartModule - Started
07:57:07:450 | MD |      INFO  | +0     | StartModule - MEmu: RetroArch
					MEmuV: v05-11-2015 Nightly
					MURL: http://themaister.net/retroarch.html
					MAuthor: djvj,zerojay
					MVersion: 2.4.2
					MCRC: A8D5F162
					iCRC: F7B77133
					MID:
					MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-Bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","ScummVM","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Dreamcast","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Meganet","Sega Nomad","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sony PSP Minis","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
07:57:07:450 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Nintendo Entertainment System"
07:57:07:451 | MD |      INFO  | +0     | PluginInit - Started
07:57:07:451 | MD |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\HyperSpin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml exists
07:57:07:471 | MD |      INFO  | +31    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
07:57:07:471 | MD |      INFO  | +0     | BuildAssetsTable - Ended
07:57:07:471 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
07:57:07:512 | MD |      INFO  | +31    | BuildAssetsTable - Ended
07:57:07:512 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
07:57:07:513 | MD |      INFO  | +0     | BuildAssetsTable - Ended
07:57:07:513 | MD |      INFO  | +0     | PluginInit - Ended
07:57:07:535 | MD |      INFO  | +32    | StartModule - Ended
07:57:07:536 | MD |      INFO  | +0     | Module - Using these system variables:
07:57:07:536 | MD |      INFO  | +0     | Module - retroSystem: Nintendo Entertainment System
07:57:07:536 | MD |      INFO  | +0     | Module - retroID: LibRetro_NES
07:57:07:536 | MD |      INFO  | +0     | Module - retroCore: nestopia_libretro
07:57:07:536 | MD |      INFO  | +0     | Module - retroMAMEID: nes
07:57:07:536 | MD |      INFO  | +0     | Module - retroMAMEMedia: cdrom
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Fullscreen: true (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - ConfigFolder: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\config (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - BIOS_Roms_Folder: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Nag_Screen: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Info_Screen: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Hide_Warning_Screen: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - HideConsole: true (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Eject_Toggle_Key: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Next_Disk_Key: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Previous_Disk_Key: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - LibRetro_Core: nestopia_libretro (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - SuperGameBoy: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Enable_Network_Play: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Overlay: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - VideoShader: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - AspectRatioIndex: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportWidth: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportHeight: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportX: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - CustomViewportY: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - StretchToFillBezel: false (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - Rotation: 0 (DEFAULT)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - CropOverscan: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - ThreadedVideo: (NO VALUE)
07:57:07:536 | MD |      INFO  | +0     | RIniFile.Read - Module - VSync: (NO VALUE)
07:57:07:537 | MD |      INFO  | +0     | RIniFile.Read - Module - IntegerScale: (NO VALUE)
07:57:07:537 | MD |      INFO  | +0     | RIniFile.Read - Module - ConfigurationPerCore: false (DEFAULT)
07:57:07:537 | MD |      INFO  | +0     | CheckFile - Checking if C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\cores\nestopia_libretro.dll exists
07:57:07:537 | MD |      INFO  | +0     | Module - Global cfg should be: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg
07:57:07:537 | MD |      INFO  | +0     | Module - System cfg should be: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\config\Nintendo Entertainment System.cfg
07:57:07:537 | MD |      INFO  | +0     | Module - Core cfg should be: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\config\nestopia_libretro.dll.cfg
07:57:07:538 | MD |      INFO  | +0     | Module - Found a Global cfg!
07:57:07:538 | MD |      INFO  | +0     | Module - RetroArch is using C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg as its config file.
07:57:07:538 | MD |      INFO  | +0     | LoadProperties - Started and loading this cfg into memory: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg
07:57:07:538 | MD |      INFO  | +0     | LoadProperties - Ended
07:57:07:538 | MD |      INFO  | +0     | Module - Reading / creating system ini for specific settings.
07:57:07:538 | MD |      INFO  | +0     | File.CheckFile - Checking if "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch-core-options.cfg" exists
07:57:07:539 | MD |      INFO  | +0     | LoadProperties - Started and loading this cfg into memory: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch-core-options.cfg
07:57:07:539 | MD |      INFO  | +0     | LoadProperties - Ended
07:57:07:539 | MD |      INFO  | +0     | RIniFile.Read - Module - Nestopia_Blargg_NTSC_Filter: disabled (DEFAULT)
07:57:07:539 | MD |      INFO  | +0     | RIniFile.Read - Module - Nestopia_Palette: canonical (DEFAULT)
07:57:07:539 | MD |      INFO  | +0     | RIniFile.Read - Module - Nestopia_Remove_Sprites_Limit: disabled (DEFAULT)
07:57:07:539 | MD |      INFO  | +0     | SaveProperties - Started and saving this cfg to disk: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch-core-options.cfg
07:57:07:540 | MD |      INFO  | +0     | SaveProperties - Ended
07:57:07:540 | MD |      INFO  | +0     | Module - Retroarch standard mode enabled
07:57:07:540 | MD |      INFO  | +0     | Module - Saving changed settings to: "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg"
07:57:07:540 | MD |      INFO  | +0     | SaveProperties - Started and saving this cfg to disk: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg
07:57:07:541 | MD |      INFO  | +0     | SaveProperties - Ended
07:57:07:542 | MD |      INFO  | +0     | Process.Run - Running: C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.exe  "I:\Arcade\Games\Nintendo Entertainment System\ROMS\Adventure Island 3 (USA).7z" -f -c "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\retroarch.cfg" -L "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\cores\nestopia_libretro.dll" -s "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\srm\Nintendo Entertainment System\Adventure Island 3 (USA).srm" -S "C:\Users\AdamG\Desktop\temporary drive holdings\Arcade\Emulators\RetroArch\save\Nintendo Entertainment System\Adventure Island 3 (USA).state"
07:57:07:563 | MD |   WARNING  | +31    | Process.Run - Showing Command Window to troubleshoot launching. ProcessID: 9680
07:57:07:563 | MD |      INFO  | +0     | Window.Wait - Waiting for window ""
07:57:46:399 | MD |     ERROR  | +38828 | ScriptError - There was an error waiting for the window "". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
07:57:46:399 | MD |      INFO  | +0     | ExitModule - Started
07:57:46:399 | MD |      INFO  | +0     | Starting Updating Statistics:
07:57:46:528 | MD |      INFO  | +125   | Game section statistics updated.
07:57:46:528 | MD |      INFO  | +0     | ExitModule - Ended
End of Module Logs
07:57:46:579 | RL |      INFO  | +39250 | Main - Module ended, exiting RocketLauncher normally
07:57:46:579 | RL |      INFO  | +0     | ExitScript - Started
07:57:46:582 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
07:57:46:690 | RL |      INFO  | +110   | SystemCursor - Restoring mouse cursor
07:57:46:693 | RL |      INFO  | +0     | ExitScript - Restored cursor
[/code]
Does anyone know of a way to use the most up to date version of RetroArch?  That N64 emulation is pretty grand among other features I would like to use.
  • 9 months later...
I did but man, I really do not remember how to do it.  It was something about saving the individual settings for each system.  I made a youtbe video though.  Let me link that for you.  Hopefully it helps.
through rocket launcher in  N64 select  retroach as defualt emulator
go to emulator sitting   ( which is a small folder with a sign of gear on it ) clik it chose the liberto which  in cores in in retro arch directory  for N64  select ( mupen 64 )
and dont forget to drop the bios in retroarch system folder.
hope i helped
