I can't figure it out...
BostonD
I recently upgraded my mobo and cpu and after the migration was done I can no longer launch games from Hyperspin and joy to key no longer autostarts with HS.  Couple of things, yes I've already checked the settings.ini path- it reads correctly.  My copy of rocketlauncher is at the root of c: and reads: Hyperlaunch_Path=C:\RocketLauncher\RocketLauncher.exe
I checked rocketlauncherui and the fronteend is pointing to Hyperspin.
I can launch games from RL and rocketlauncherUI
I'm at a loss and just not sure what the issue is
04:48:16 PM |  HyperSpin Started
04:48:16 PM |  Going FullScreen
04:48:16 PM |  Checking for updates
04:48:16 PM |  Update Check Complete
04:48:16 PM |  Startup program: JoyToKey.exe
04:48:16 PM |  Startup params: exe
04:48:16 PM |  Working directory: C:\HyperSpin\JoyToKey_en\
04:48:16 PM |  Window State: MINIMIZED
04:48:16 PM |  Launching JoyToKey.exe
04:48:16 PM |  Command Line is JoyToKey.exe exe
04:48:16 PM |  Playing intro video
04:48:18 PM |  Error intializing joysticks
04:48:18 PM |  Menu Mode is multi
04:48:18 PM |  Loading Main Menu.xml
04:48:18 PM |  Main Menu.xml successfully loaded
04:48:18 PM |  Main Menu wheel loaded successfully
04:48:19 PM |  Loading Sammy Atomiswave.xml
04:48:20 PM |  roms_only is true, checking files
04:48:20 PM |  Main Menu.xml successfully loaded
04:48:20 PM |  Sammy Atomiswave wheel loaded successfully
04:48:20 PM |  Launching Game
04:48:20 PM |  Using HyperLaunch
04:48:20 PM |  Getting Launcher path
04:48:20 PM |  Launcher located at C:\RocketLauncher\RocketLauncher.exe
04:48:20 PM |  Running Launcher
04:48:20 PM |  Launcher Command Line is: C:\RocketLauncher\RocketLauncher.exe "Sammy Atomiswave" "dolphin"
04:48:26 PM |  Launching Game
04:48:26 PM |  Using HyperLaunch
04:48:26 PM |  Getting Launcher path
04:48:26 PM |  Launcher located at C:\RocketLauncher\RocketLauncher.exe
04:48:26 PM |  Running Launcher
04:48:26 PM |  Launcher Command Line is: C:\RocketLauncher\RocketLauncher.exe "Sammy Atomiswave" "dolphin"
04:48:27 PM |  Launching Game
04:48:27 PM |  Using HyperLaunch
04:48:27 PM |  Getting Launcher path
04:48:27 PM |  Launcher located at C:\RocketLauncher\RocketLauncher.exe
04:48:27 PM |  Running Launcher
04:48:27 PM |  Launcher Command Line is: C:\RocketLauncher\RocketLauncher.exe "Sammy Atomiswave" "dolphin"
04:48:30 PM |  Loading Main Menu.xml
04:48:30 PM |  Main Menu.xml successfully loaded
04:48:31 PM |  Main Menu wheel loaded successfully
04:48:32 PM |  Exit program: JoyToKey.exe
04:48:32 PM |  Exit params: exe
04:48:32 PM |  Working directory: C:\HyperSpin\JoyToKey_en\
04:48:32 PM |  Window State: NORMAL
04:48:32 PM |  Launching JoyToKey.exe
04:48:32 PM |  Command Line is JoyToKey.exe exe
04:48:32 PM |  Quiting Hyperspin
04:48:32 PM |  Bye!
I dont believe it is-this is the first post set I've made here in this community as I've done well figuring things on my own and like I said everything worked perfectly then boom-this mess.
Question-if you don't use joy to key-then how do you go about getting a joystick to work with HS?
