Disabling Transitions
raungst
I've searched and searched, and I can't figure out how to disable transitions. I'm making a custom system theme, and the random pan/zoom transition as I switch from system to system on the main screen isn't what I was hoping for. Is there a way to disable it?
I've tried renaming the Media/Front End/Video/Transitions folder, removing all the files from the folder, and also unchecking everything in the optimizer tab. What am I missing?
  • 10 months later...
Hello, N00B here and this is my first post. While I'm a huge fan of Hyperspin, I don't like the transitions. I'd rather have the system "private labeled" as my own arcade. I may create new transitions, but in the meantime I found an easy way to eliminate them. Just replace the four transitions from this folder with the ones in the Media/Front End/Video/Transitions folder and you won't see any transitions. These replacement files are essentially blank .FLV files with one pixel in them. The transition feature is cool so I'll probably build some customized ones and share them, as well. Thanks to the founders/maintainers/contributors to this site - it's a positive community and I'm amazed at how "buttoned up" the documentation and coding is for an open source project. https://drive.google.com/open?id=0B1gxfVGRbubKcm01OEUybUFBRkE
Also, if I should post this somewhere else or upload the files to a HS folder I'm happy to do it...just need a mod or someone to let me know where it should go.
  • 6 months later...
Does this no longer work? I can't seem to get rid of the "exit tranisitions" for wheel art and such on my theme...it looks stupid.
  • 2 months later...
