MAME not working.
woosdom
In addition to ensuring you have a MAME.xml database file in \databases\MAME\ folder, you also may have additional filters enabled in the MAME.ini.    If you have the filters enabled (roms, wheels, themes) but have no files, you'll see no games listed in the wheel.
I do have a database but I need to check for the filters. will do that ASAP. thanks
well I packed my controller so I'll have to wait until tomorrow to test it. :/
If you can pick one game, let's focus on that first.
Post parts of your .ini showing rompath, romext, filters, and exe/param lines.
Is text listed in wheel showing game names? If not, dbase may be corrupt.
What are filenames of related game media?
What is full path and name of the rom?
Which emulator are you using for game boy?
  • 6 months later...
  • 4 weeks later...
Which MAME emulator are you using? MAME Reloaded?  Retroarch?
Is the wheel working on PC but not on Android?
Common issues can be mixed up naming between wheel name is 'main menu' dbase, media folder, and rom name path as it relates to filtering by roms.
Yes my mame works on pc but not android. iv downloaded all emulators in retroarch for android. When i posted my last message last night i checked where my ini was searching for my mame directory and it looked like it check ok i also check theat the names of files listed in the ini and also that checked out ok. Ill check out what i can do with what you have described tonight when i finished work. Thanks for your help mate ill keep you posted
Mamereloaded works well IF you have u139.1 romset and they are .zip files (it does not support .7z)
Retroarch MAME core is GIT so would be 169 roms?
MAME2014 core (broken on nightly builds atm) :-( uses ~v159 rom set (and does support .7z)
MAME2003 core is ~v78.
Sorry for not replying sooner Ok i had a play about for a while and still cant get hyperspin to find MAME what so ever. my roms are in zip file but havent moved them over yet as i will be deleting some systems what i wont be using on my tab for more space.iv got all artwork/video my only thought is that my mame is categorised sport/fighting/racing/ect but i do have a exe file with all my roms names in with that and same with video content but i allso have all my vids single in with the video folder so dont think that would make a difference. Ill have another play about with it in the morning when i get chance and go through what iv got
iv checked all folders and everything seems to be their and everything that is labeled MAME is in caps i just cant seem to get it to corrispond at all. here is my ini for mame iv had it up against neo geo and it seems to check out ok to me.
[exe info]
path=H:\hyperspin\emulators\MAME\
rompath=Emulators/MAME/roms/
userompath=true
exe=com.seleuco.mame4droid/com.seleuco.mame4droid.MAME4droid
romextension=zip
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Per_Game_Modules=false
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
[filters]
parents_only        = false
themes_only         = false
wheels_only         = false
roms_only    = false
[themes]
use_parent_vids=false
use_parent_themes=false
animate_out_default=false
reload_backgrounds=true
[wheel]
alpha=.15
small_alpha = 1
style               = normal
speed               = high
pin_center_width    = 500
horz_wheel_y        = 512
vert_wheel_position=right
y_rotation          = right
norm_large          = 360
norm_small          = 230
vert_large          = 400
vert_small          = 240
pin_large           = 500
pin_small           = 200
horz_large          = 240
horz_small          = 150
letter_wheel_x      = 800
letter_wheel_y      = 384
text_width          = 700
text_font           = Style2
small_text_width    = 260
large_text_width    = 400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance     = 0
shadow_angle        = 45
shadow_color=0x000000
shadow_alpha        = 1
shadow_blur         = 0
[pointer]
animated=true
x                   = 975
y                   = 384
[video defaults]
path=H:\hyperspin\Media\MAME\Video\
[sounds]
game_sounds         = true
wheel_click         = true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=false
remove_info_text=true
use_last_game=true
last_game=thunderl
random_game=false
start_on_favorites=false
[special Art A]
default=true
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[special Art C]
active=false
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active    = true
show_year           = true
show_manf           = true
show_description    = true
text_color1         = 0xFFFFFF
text_color2         = 0xFFFFFF
stroke_color        = 0x000000
text_font           = Style3
text1_textsize      = 26
text1_strokesize    = 7
text1_x             = 32
text1_y             = 610
text2_textsize      = 36
text2_strokesize    = 8
text2_x             = 30
text2_y             = 640
