aimtrak light guns
jimbojones
i posted this a while back and no one responded so i though i would give it a go again
I have 2 aimtrak light guns set up in mame and for the most part work good except when i enable any one of the following "triple buffering, "sync to monitor refresh rate" or "wait for vertical sync".
i have tried numerous versions of mame but with the same outcome. all the mame builds are with forced direct input.
once i enable any one of those options, i encounter huge input lags. if i disable all of them then the gun sights move smoothly and track along the screen properly. however i then get a lot of screen tears.
zombie raid is horrible to play this way
i am running windows 7 with a quad core q6600  2.4 GHz with 8 gigs DDR2 ram pc6400 with geforce 9600gt.
i am running s-video output to a 27 CRT tv monitor @480i with 30 hz refresh rate (which i think may be causing the issue).
i dont have an older video card to play with different resolutions and refresh rates
does anyone else have this issue?
