HELP!! RetroArch sending me crazy!!
egatimra
Ok, so, ive finally sat down, and setup my Hyperspin on my Shield.
​Ive got a theme loaded, ive got videos and artwork, and ive got my roms.
My Roms are on a Nas but Hyperspin sees them.
The real issue come with Retro Arch! For some reason it simply hits a default CFG every single time I try and load from Hyperspin.
Ive followed the advice that Ive seen "thatman84" post and I know he knows what hes talking about but I simply cant get Hyperspin to work.
If I load retro arch without HS I cant configure the Directorys etc and setup my cores.  Then each time I enter RA it works as id expect
However if I load via HS I get the default config.  Now I can change the settings while in this and then play game but if I come out and go back in...... Its back to default.
I think its something to do with the default paths being /data/data but I cant seem to find these (guessing they are locked away) but I'm simpy now going crazy! I know once I resolve for one system (Genesis) The others will fall into play...... perhaps I'm missing something silly.... and need a step by step instruction, although as mentioned I have used most of thatman89's posts.
So there you go......HELP!!!!
LOL
Here I am again!! Hopefully this one will work for you. (just jumped on to do a vid for this but controller is messing about, 1st time I had that!!)
If you are using a new RetroArch build then they dont use per core configs anymore. Just overrides. I believe you can save overrides from within the menus now. I think it creates a folder in the config directory named similar to the core (Maybe Genesis Plus GX for example) In that folder is the cfg file named the same with just the lines of config that differ from how your retroarch.cfg file is setup. (I have not bothered to upgrade
Just confirm for yourself Genesis is setup in RetroArch AND for the same core that is launched by the HS parameter= line in the ini
Check you have a retroarch cfg file for that core in your config directory (mine is sdcard/RetroArch/config/genesis_plus_gx_libretro_android.so.cfg)
OR your override structure is there. Either should work
Check you have Save on Exit enabled under settings-configuration
so now launch a genesis game in HS.
bring up the retroarch menu
back out of quick menu
go to setings->directory
change it to point to the default config directory. (sdcard/rtroarch/config)
back out to the menu where load content is and hit Save Current config
go and resume game. wait a bit and go back in and check
DONT quit retroarch with a hotkey.
go back into menu and then Quit via the retroarch option
see if that works.
if not
load ANY game from any retroarch core by launching from hyperspin
go into menu and close game.
now go and change the directory then save then quit via menu
see if that works
IF not try this!
open retroarch outside of hyperspin
go to settings->directory
change this to the root directory by using "Application Dir" heading then "<use this directory>" straight away
now go out to the main menu
hit "Load Configuration" (this takes you to Root and the retroarch.cfg that HS uses
Scroll down and load retroarch.cfg
Now go back into settings->directory
again change the config directory to where your configs are
go back and save CURRENT
quit and launch from HS
If none of those work Your screwed or im Shite!!
hope that helps
Haha figured you'd reply your hyperspin senses must have been tingling
I'm use the store build 3.6 something I think or 3 something 6. Anyways I'll wipe that from box, and the retroarch folder that is created on root of drive. Then I'll go through your steps above. It's so close this is the last bit, once this works I can crack on with other systems and polish up the art stuff etc..... oh you were right about those cinematic themes, for the main menu, they are spot on, could do with finding similar now for when you select the system so any ideas holla back!
Your good with play store version 1.3.6 that's what I use.
Ignore the override stuff
In settings->configuration
Have per core config ON
Load overrides OFF
Load a game from HS
Change the directory to the one that's listed in directories when launched outside of HS
Save and that should be it
Cinematic are cool man
Not sure on system themes. I'm thinking of creating a global default one maybe so not been to bothered really
looks like im screwed..... an changes i make seem to revert back to default config.... if i take an over lay off, etc i load back up a game.... over lay is there. i load outside of HS and it works as id expect?
ok.....now seems like I'm not screwed..... but don't seem to know why....... I'm gonna finish the setup and see what happens
Sounds like it's not saving the path to the right directory. Double check the config directory path in retroarch only, then Hyperspin.
