Launching steam games fails
uselessmidget
well, the obvious question is, are you pointing the path to a file and not a folder?
I believe you cannot set it to the exe and use the steamid. It comes up with an error that says so when you try to launch it. When doing just the exe I've gotten some of the lower tech games to run. But street fighter, pinball fx2, & CS:GO all will not launch by just the exe path or exe path w/ fade title.
also I have daemon stuff disabled.
Edit: Confirmed, when trying to use Application & SteamID at the same time I receive this error: You are trying to use Steam & Application, you must choose one or the other."
All you need to add is the Steam ID, do not add both. If that is still not working, post your log.
Yeah thats what I thought. I tried that, I have also added games not already listed to "SteamIDs.ini", & I have done the encrypted password deal to save my steam password within.
Exactly where is the log and what is the filename so I can post?
Thanks for your help
It's in your RocketLauncher folder and is called RocketLauncher.log
Thanks.
Here it is:
14:28:46:703 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
14:28:46:812 | RL |     INFO  | +109   | Main - System Specs:
RocketLauncher Dir: I:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows XP Professional
SKU:
Total Memory: 3322.86 MB
Free Memory: 2396.64 MB
Used Memory: 926.219 MB
SystemType: 32-bit
Physical Processors: See Logical in XP
Logical Processors: 1
GPU 1 Name: AMD Radeon HD 5700 Series
GPU 1 RAM: 1024.00 MB
GPU 1 Driver Version: 6.14.10.7279
Sound 1 Device: AMD High Definition Audio Device
Sound 1 Status: Enabled
Sound 2 Device: USB Audio Device
Sound 2 Status: Enabled
Sound 3 Device: IDT High Definition Audio CODEC
Sound 3 Status: Enabled
OS Admin Status: Yes
Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x738 work) [Landscape] (Primary)
Current AHK Desktop Width: 1024
Current AHK Desktop Height: 768
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
14:28:46:812 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\RocketLauncher.exe exists
14:28:46:812 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Plugins\HyperSpin.plugin exists
14:28:46:812 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
14:28:46:812 | RL |     INFO  | +0     | Main - RocketLauncher received "PC Games" and "FEZ"
14:28:46:828 | RL |     INFO  | +16    | Main - Did not find a "I:\RocketLauncher\Settings\PC Games\Game Options.ini" file, skipping any game-specific options.
14:28:46:828 | RL |     INFO  | +0     | Main - FEZ is using the default emulator: PCLauncher
14:28:46:828 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in I:\RocketLauncher\Settings\PC Games\Emulators.ini
14:28:46:828 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in I:\RocketLauncher\Settings\Global Emulators.ini
14:28:46:828 | RL |     INFO  | +0     | Main - Found [PCLauncher] in I:\RocketLauncher\Settings\Global Emulators.ini
14:28:46:828 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk exists
14:28:46:828 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
14:28:46:828 | RL |     INFO  | +0     | Main - FEZ will use module: I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk
14:28:46:859 | RL |     INFO  | +31    | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher".
14:28:46:859 | RL |     INFO  | +0     | Main - INI Keys read
14:28:46:859 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Module Extensions\7z.exe exists
14:28:46:859 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Module Extensions\7z.dll exists
14:28:46:859 | RL |     INFO  | +0     | Main - "FEZ" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
14:28:46:859 | RL |     INFO  | +0     | CheckPaths - Started
14:28:46:859 | RL |     INFO  | +0     | CheckPaths - Ended
14:28:46:859 | RL |     INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
DetectHiddenWindows, ON
SetTitleMatchMode, 2
SendMode, Event
0 = 10
pluginPath = I:\RocketLauncher\Plugins
pluginName = HyperSpin
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.0.1.2
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = I:\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID =
frontendPath = I:\Hyperspin
frontendExe = HyperSpin.exe
frontendExt = exe
frontendName = HyperSpin
frontendDrive = I:
exitEmulatorKey = ~Esc
exitEmulatorKeyWait = 0
forceHoldKey = ~Esc
restoreFE = false
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath =
emuPath =
emuName = PCLauncher
emuExt =
romPath =
romPathFromIni =
romExtension =
romExtensionOrig =
romExtensions =
executable =
systemDbName = PC Games
systemName = PC Games
dbPath =
dbName = FEZ
dbExt =
romName =
romMapPath =
romMappingEnabled = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = I:\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
logFile = I:\RocketLauncher\RocketLauncher.log
logLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]
logLevel = 3
logShowDebugConsole = false
logIncludeModule = true
logShowCommandWindow = false
logCommandWindow = false
rlDebugConsoleStdout =
sysType = 32-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1024
originalHeight = 768
vdEnabled = false
vdFullPath =
vdUseSCSI = false
vdDriveLetter =
vdAddDrive = true
servoStikEnabled = false
ledblinkyEnabled = false
ledblinkyFullPath =
ledblinkyProfilePath = I:\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = I:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeWidthBaseRes = 1920
fadeHeightBaseRes = 1080
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = imageandbar
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeBarNon7zProgressTime = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoManufacturer = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoTextMargin = 7
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey =
detectFadeErrorEnabled = true
fadeImgPath = I:\RocketLauncher\Media\Fade
RLDataPath = I:\RocketLauncher\Data
RLMediaPath = I:\RocketLauncher\Media
RLErrSoundPath = I:\RocketLauncher\Media\Sounds\Error
modulesPath = I:\RocketLauncher\Modules
moduleFullName = I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk
moduleName = PCLauncher
modulePath = I:\RocketLauncher\Modules\PCLauncher
moduleExtension = ahk
moduleExtensionsPath = I:\RocketLauncher\Module Extensions
libPath = I:\RocketLauncher\Lib
7zEnabled = false
7zPath = I:\RocketLauncher\Module Extensions\7z.exe
7zDllPath = I:\RocketLauncher\Module Extensions\7z.dll
7zExtractPath = H:\Documents and Settings\Administrator\Local Settings\Temp\HS
7zExtractPathOrig =
7zAttachSystemName = false
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1920
mgHeightBaseRes = 1080
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = I:\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keymapperEnabled = false
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = I:\Utilities\Xpadder\xpadder.exe
joyToKeyFullPath = I:\Utilities\JoyToKey\JoyToKey.exe
keymapperProfilePath = I:\RocketLauncher\Profiles\xpadder
keymapperFrontEndProfileName = RocketLauncherUI
joyIDsEnabled = false
joyIDsPreferredControllersGlobal =
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit =
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = I:\RocketLauncher\Profiles\xpadder\RocketLauncherUI
defaultProfile = I:\RocketLauncher\Profiles\xpadder\_Default
systemProfile = I:\RocketLauncher\Profiles\xpadder\PC Games
xPadderSystemProfile = I:\RocketLauncher\Profiles\xpadder\PC Games\_Default
emuProfile = I:\RocketLauncher\Profiles\xpadder\PC Games\PCLauncher
romProfile = I:\RocketLauncher\Profiles\xpadder\PC Games\FEZ
RocketLauncherProfile = I:\RocketLauncher\Profiles\xpadder\RocketLauncher
blankProfile = I:\RocketLauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = I:\RocketLauncher\Profiles\AHK\RocketLauncherUI
ahkDefaultProfile = I:\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = I:\RocketLauncher\Profiles\AHK\PC Games
ahkEmuProfile = I:\RocketLauncher\Profiles\AHK\PC Games\PCLauncher
ahkRomProfile = I:\RocketLauncher\Profiles\AHK\PC Games\FEZ
ahkRocketLauncherProfile = I:\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
statisticsEnabled = true
pressDuration = -1
emuVolume = 1
dxwndIni = I:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = I:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
mon1O =
pacDrivedllFile = I:\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = I:\RocketLauncher\Lib\User Fade Animations.ini
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
14:28:46:859 | RL |  WARNING  | +0     | BuildScript - "I:\RocketLauncher\Lib\User Functions Init.ahk" not found
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Validating module
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Validation complete
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Module:
MEmu = PCLauncher
MEmuV =  N/A
MURL = http://www.rlauncher.com/wiki/index.php?title=PCLauncher
MAuthor = djvj
MVersion = 2.1.6
MCRC = AEF9EDF1
iCRC = 2DC5F958
mId = 635243126483565041
MSystem = "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project"
; Notes:
; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications.
; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems.
; Read the comments at the top of ini for the definitions of each key.
; For informaion on how to use this module and what all the settings do, please see https://sites.google.com/site/RocketLauncher2/additional-features/pclauncher
StartModule()
If (romExtensions != "")
ScriptError("PCLauncher does not use extensions, but you have them set to: """ . romExtensions . """. Please remove all extensions from the PCLauncher emulator in RocketLauncherUI to continue using it.")
IfExist, % modulePath . "\" . systemName . ".ini" ; use a custom systemName ini if it exists
settingsFile := modulePath . "\" . systemName . ".ini"
Else
settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini", "Could not find """ . modulePath . "\" . moduleName . ".ini"". RocketLauncherUI will create this file when you configure your first game to be used with this " . MEmu . " module.")
iniLookup = SteamID|Application|AppWaitExe|DiscImage|Parameters|OriginGame|DXWndGame|WorkingFolder|PreLaunch|PreLaunchParameters|PreLaunchSleep|PostLaunch|PostLaunchParameters|PostLaunchSleep|PostExit|PostExitParameters|PostExitSleep|ExitMethod|FadeTitle|FadeInExitSleep|BezelEnabled
Loop, Parse, iniLookup, |
{ %A_LoopField% := IniReadCheck(settingsFile, dbName, A_LoopField, A_Space,,1)
If A_LoopField in Application
If (!Application && !SteamID) { ; Create keys if they do not exist in the ini and this is not a steam game
IniWrite, %A_Space%, %SettingsFile%, %dbName%, %A_LoopField%
missingKeys = 1
; These settings enable them to be customized per-game in this module
bezelEnabled := IniReadCheck(settingsFile, "Settings|" . dbName, "BezelEnabled",,,1)
If bezelEnabled = true
BezelGUI()
FadeInStart()
BezelStart()
If (missingKeys && !SteamID)
ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.")
; If Application needs a cd/dvd image in the drive, mount it in DT first
If DiscImage {
Log("PCLauncher - Application is a Disc Image, mounting it in DT")
appIsImage=1
DiscImage := GetFullName(DiscImage) ; convert a relative path defined in the PCLauncher ini to absolute
CheckFile(DiscImage,"Cannot find this DiscImage for " . dbName . ":`n" . DiscImage)
SplitPath,DiscImage,,ImagePath,ImageExt,ImageName
If ImageExt in mds,mdx,b5t,b6t,bwt,ccd,cue,isz,nrg,cdi,iso,ape,flac
{ VirtualDrive("get") ; get the vdDriveLetter
VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt)
} Else
ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg")
; Verify module's settings are set
CheckSettings()
If PreLaunch {
Log("PCLauncher - PreLaunch set by user, running: " . PreLaunch)
PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR" ) ? "" : PreLaunchParameters
errLevel := Run(If preLSkip ? PreLaunch : """" . PreLaunchName . """ " . PreLaunchParameters, PreLaunchPath)
If errLevel
ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.")
Sleep, %PreLaunchSleep%
If DXWndGame = true ; start dxwnd if needed
DxwndRun()
If mode in steam,steambp ; steam launch
Steam(SteamID, Application, Parameters)
Else If mode = origin ; origin launch
Origin(ApplicationName, ApplicationPath, Parameters)
Else {
If mode = url
{ Log("PCLauncher - Launching URL.")
errLevel := Run(Application)
} Else { ; standard launch
Log("PCLauncher - Launching a standard application.")
errLevel := Run("""" . (If WorkingFolder ? ApplicationPath . "\" : "") . ApplicationName . """ " . Parameters, If WorkingFolder ? WorkingFolder : ApplicationPath,, AppPID)
If errLevel
ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.")
If PostLaunch {
Log("PCLauncher - PostLaunch set by user, running: " . PostLaunch)
PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR" ) ? "" : PostLaunchParameters
errLevel := Run(If postLSkip ? PostLaunch : """" . PostLaunchName . """ " . PostLaunchParameters, PostLaunchPath)
If errLevel
ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.")
Sleep, %PostLaunchSleep%
If FadeTitle {
Log("PCLauncher - FadeTitle set by user, waiting for """ . FadeTitle . """")
WinWait(FadeTitle)
WinWaitActive(FadeTitle)
} Else If AppWaitExe {
Log("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe)
AppWaitPID := Process("Wait", AppWaitExe, 15)
If AppWaitPID = 0
ScriptError("PCLauncher - There was an error getting the Process ID from your AppWaitExe for """ . dbName . """. Please try setting a FadeTitle instead.")
} Else If SteamIDExe {
Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe)
SteamIDPID := Process("Wait", SteamIDExe, 15)
If SteamIDPID = 0
ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.")
} Else If AppPID {
Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: " . AppPID)
WinWait("ahk_pid " . AppPID)
WinWaitActive("ahk_pid " . AppPID)
} Else
Log("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for",3)
BezelDraw()
Sleep, %FadeInExitSleep% ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer
FadeInExit()
If AppWaitExe {
SplitPath,AppWaitExe,AppWaitExe ; In case someone set this as a path accidentally, only want the filename from this key
Log("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe . """ to close.")
Process("WaitClose", AppWaitExe)
} Else If FadeTitle { ; If fadeTitle is set and no appPID was created.
Log("PCLauncher - Waiting for FadeTitle """ . FadeTitle . """ to close.")
WinWaitClose(FadeTitle)
Log("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe . """ to close.")
Process("WaitClose", SteamIDExe)
} Else If AppPID {
Log("PCLauncher - Waiting for AppPID """ . AppPID . """ to close.")
Process("WaitClose", AppPID)
} Else
ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.")
If PostExit {
Log("PCLauncher - PostExit set by user, running: " . PostExit)
PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR" ) ? "" : PostExitParameters
errLevel := Run(If postESkip ? PostExit : """" . PostExitName . """ " . PostExitParameters, PostExitPath)
If errLevel
ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.")
Sleep, %PostExitSleep%
; If Application is a cd/dvd image, unmount it in DT
If appIsImage
VirtualDrive("unmount")
; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now
; If AppPID = 0
; Run, Steam.exe -shutdown, %SteamPath% ; close steam
If DXWndGame = true
DxwndClose()
BezelExit()
FadeOutExit()
ExitModule()
CheckSettings() {
Global Application,ApplicationPath,ApplicationName,ApplicationExt
Global PreLaunch,PreLaunchPath,PreLaunchName,PreLaunchExt
Global PostLaunch,PostLaunchPath,PostLaunchName,PostLaunchExt
Global PostExit,PostExitPath,PostExitName,PostExitExt
Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,preLSkip,postLSkip,postESkip,AppWaitExe,SteamIDExe,FadeTitle
Global modulePath,fadeIn
Log("CheckSettings - Started")
; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work
If (SteamID) {
mode = steam ; setting module to use steam mode
Log("PCLauncher - SteamID is set, setting mode to: """ . mode . """")
} Else If (SubStr(Application,1,3) = "ste") {
mode = steambp ; setting module to use Steam Browser Protocol mode
Log("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """")
} Else If (SubStr(Application,1,4) = "http") {
mode = url ; setting module to use url mode
Log("PCLauncher - Application is a URL, setting mode to: """ . mode . """")
} Else If OriginGame {
mode = origin ; setting module to use Origin mode
Application := GetFullName(Application) ; convert a relative path defined in the PCLauncher ini to absolute
SplitPath,Application,ApplicationName,ApplicationPath,ApplicationExt
StringRight, ApplicationBackSlash, Application, 1
Log("PCLauncher - Origin mode enabled. Will log in to Origin if required.")
} Else If Application {
mode = standard ; for standard launching
Log("PCLauncher - Setting mode to: """ . mode . """")
} Else ; error if no modes are used
ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """")
If (SteamID && Application) ; do not allow 2 launching methods
ScriptError("You are trying to use Steam and Application, you must choose one or the other.")
If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini
SteamIDFile := CheckFile(modulePath . "\SteamIDs.ini")
If !SteamID
SplitPath, Application,SteamID ; grab the
SteamIDExe := IniReadCheck(SteamIDFile, SteamID, "exe","",,1)
If !SteamIDExe
ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10)
Else
Log("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """")
} Else If (mode = "url" && !AppWaitExe && !FadeTitle)
ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10)
preLSkip := If (SubStr(PreLaunch,1,4)="http" || SubStr(PreLaunch,1,3)="ste") ? 1:""
If preLSkip
Log("PCLauncher - PreLaunch is a URL or Steam Browser Protocol: " . PreLaunch)
postLSkip := If (SubStr(PostLaunch,1,4)="http" || SubStr(PostLaunch,1,3)="ste") ? 1:""
If postLSkip
Log("PCLauncher - PostLaunch is a URL or Steam Browser Protocol: " . PostLaunch)
postESkip := If (SubStr(PostExit,1,4)="http" || SubStr(PostExit,1,3)="ste") ? 1:""
If postESkip
Log("PCLauncher - PostExit is a URL or Steam Browser Protocol: " . PostExit)
If (ApplicationBackSlash = "\")
ScriptError("Please make sure your Application does not contain a backslash on the end:`n" . Application)
If (appIsImage && !ApplicationPath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted
ApplicationPath := vdDriveLetter . ":\"
If (!ApplicationName && mode = "standard" && (mode != "steam" || mode != "steambp"))
ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . Application)
If (!ApplicationExt && mode = "standard" && (mode != "steam" || mode != "steambp"))
ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . Application)
If (PreLaunch && !preLSkip) {
PreLaunch := GetFullName(PreLaunch)
SplitPath,PreLaunch,PreLaunchName,PreLaunchPath,PreLaunchExt
StringRight, PreLaunchBackSlash, PreLaunch, 1
CheckFile(PreLaunch,"Cannot find this PreLaunch application:`n" . PreLaunch)
If (PreLaunchBackSlash = "\")
ScriptError("Please make sure your PreLaunch does not contain a backslash on the end:`n" . PreLaunch)
If (PostLaunch && !postLSkip) {
PostLaunch := GetFullName(PostLaunch)
SplitPath,PostLaunch,PostLaunchName,PostLaunchPath,PostLaunchExt
StringRight, PostLaunchBackSlash, PostLaunch, 1
CheckFile(PostLaunch,"Cannot find this PostLaunch application:`n" . PostLaunch)
If (PostLaunchBackSlash = "\")
ScriptError("Please make sure your PostLaunch does not contain a backslash on the end:`n" . PostLaunch)
If (PostExit && !postESkip) {
PostExit := GetFullName(PostExit)
SplitPath,PostExit,PostExitName,PostExitPath,PostExitExt
StringRight, PostExitBackSlash, PostExit, 1
CheckFile(PostExit,"Cannot find this PostExit application:`n" . PostExit)
If (PostExitBackSlash = "\")
ScriptError("Please make sure your PostExit does not contain a backslash on the end:`n" . PostExit)
If mode = standard
CheckFile(ApplicationPath . "\" . ApplicationName,"Cannot find this Application:`n" . ApplicationPath . "\" . ApplicationName) ; keeping this last so more descriptive errors will trigger first
Log("CheckSettings - Ended")
CloseProcess:
If ExitMethod ; fadeout will only take effect if an ExitMethod method was set, otherwise fade will occur and application will not close
FadeOutStart()
If ( ExitMethod = "Process Close AppWaitExe" && AppWaitExe) {
Log("CloseProcess - ExitMethod is ""Process Close AppWaitExe""")
Process("Close", AppWaitExe)
} Else If ( ExitMethod = "WinClose AppWaitExe" && AppWaitExe) {
Log("CloseProcess - ExitMethod is ""WinClose AppWaitExe""")
AppWaitExePID := Process("Exist", AppWaitExe)
WinClose("ahk_pid " . AppWaitExePID)
} Else If ( ExitMethod = "Process Close Application" ) {
Log("CloseProcess - ExitMethod is ""Process Close Application""")
Process("Close", ApplicationName)
} Else If ( ExitMethod = "WinClose Application" && FadeTitle ) {
Log("CloseProcess - ExitMethod is ""WinClose Close Application""")
WinClose(FadeTitle)
} Else If ( ExitMethod = "Send Alt+F4" ) {
Log("CloseProcess - ExitMethod is ""Send Alt+F4""")
Send, !{F4}
} Else {
Log("CloseProcess - Default ExitMethod`, using ""WinClose""")
WinClose(ApplicationName)
Return
14:28:46:859 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
14:28:46:875 | RL |     INFO  | +15    | BuildScript - Loaded Statistics.ahk script
14:28:46:875 | RL |  WARNING  | +0     | BuildScript - "I:\RocketLauncher\Lib\User Functions.ahk" not found
14:28:46:875 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
14:28:46:875 | RL |     INFO  | +0     | Main - Module is built
14:28:46:875 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\AutoHotkey.dll exists
14:28:46:875 | RL |     INFO  | +0     | Main - Running module
14:28:47:000 | MD |     INFO  | +N/A   | Module initialized
14:28:47:000 | MD |     INFO  | +0     | StartModule - Started
14:28:47:000 | MD |     INFO  | +0     | StartModule - MEmu: PCLauncher
MEmuV: N/A
MURL: http://www.rlauncher.com/wiki/index.php?title=PCLauncher
MAuthor: djvj
MVersion: 2.1.6
MCRC: AEF9EDF1
iCRC: 2DC5F958
MID:
MSystem: "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project"
14:28:47:000 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "PC Games"
14:28:47:000 | MD |     INFO  | +0     | PluginInit - Started
14:28:47:000 | MD |     INFO  | +0     | CheckFile - Checking if I:\Hyperspin\Databases\PC Games\PC Games.xml exists
14:28:47:031 | MD |     INFO  | +32    | PluginInit - Ended
14:28:47:031 | MD |     INFO  | +0     | StartModule - Ended
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - SteamID: 224760
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - Application:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - AppWaitExe:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - DiscImage:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - Parameters:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - OriginGame:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - DXWndGame:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - WorkingFolder:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PreLaunch:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PreLaunchParameters:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PreLaunchSleep:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostLaunch:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostLaunchParameters:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostLaunchSleep:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostExit:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostExitParameters:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - PostExitSleep:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - ExitMethod:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - FadeTitle:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - FadeInExitSleep:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [FEZ] - BezelEnabled:
14:28:47:031 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelEnabled:
14:28:47:031 | MD |     INFO  | +0     | CheckSettings - Started
14:28:47:031 | MD |     INFO  | +0     | PCLauncher - SteamID is set, setting mode to: "steam"
14:28:47:031 | MD |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Modules\PCLauncher\SteamIDs.ini exists
14:28:47:062 | MD |     INFO  | +31    | Module Setting - [224760] - exe: FEZ.exe
14:28:47:062 | MD |     INFO  | +0     | PCLauncher - Found an exe in the SteamIDs.ini for this game: "FEZ.exe"
14:28:47:062 | MD |     INFO  | +0     | CheckSettings - Ended
14:28:47:062 | MD |     INFO  | +0     | Steam - Started
14:28:47:062 | MD |     INFO  | +0     | Steam - Received SteamID: "224760" | SteamProtocol: "" | Parameters: ""
14:28:47:062 | MD |     INFO  | +0     | GetSteamPath - Started
14:28:47:062 | MD |     INFO  | +0     | CheckFile - Checking if \ exists
14:28:48:546 | MD |    ERROR  | +1484  | ScriptError - This is a folder and must point to a file instead: \
14:28:48:546 | MD |     INFO  | +0     | ExitModule - Started
14:28:48:546 | MD |     INFO  | +0     | Starting Updating Statistics:
14:28:48:734 | MD |     INFO  | +188   | Game section statistics updated.
14:28:48:734 | MD |     INFO  | +0     | ExitModule - Ended
14:28:48:734 | MD |     INFO  | +0     | End of Module Logs
14:28:48:843 | RL |     INFO  | +1969  | Main - Module ended, exiting RocketLauncher normally
14:28:48:843 | RL |     INFO  | +0     | ExitScript - Started
14:28:48:843 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
14:28:48:843 | RL |     INFO  | +0     | ExitScript - Ended
I notice that you've called you System "PC Games" instead of Steam although it does look like the SteamID has been found etc. You've set PCLauncher as a Virtual emulator and also not set a Rom folder as well?
Also Skip checks should be set to "Rom and Emu"
If you post over at RocketLauncher make sure you post your log set to "Troubleshooting"
I notice that you've called you System "PC Games" instead of Steam although it does look like the SteamID has been found etc. You've set PCLauncher as a Virtual emulator and also not set a Rom folder as well.
Yes I was following a youtube tutorial.
Is PCLauncher not supposed to be a virtual emulator? If not then what do you select for the executable for PCLauncher setup as traditional emulator?
Do I need to set a rom folder linked to the root of each installed game? Even though it launches through a steam game ID not an exe?
I changed the setting to skip rom checks and emu checks and same thing, trying to launch by steam game ID it says this is a folder not a file
I made the changes you recommended and I'm receiving the same error.
Steam instead of PC Games, PCLauncher not set as virtual emulator, added a rom folder to install directory, skip checks rom & emu.
Do you see anything else it could be?
21:46:45:359 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
21:46:45:515 | RL |     INFO  | +157   | Main - System Specs:
SKU:
Free Memory: 2254.38 MB
Used Memory: 1068.480 MB
SystemType: 32-bit
AutoHotkey Path:
Unicode: No
21:46:45:515 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\RocketLauncher.exe exists
21:46:45:515 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Plugins\HyperSpin.plugin exists
21:46:45:515 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
21:46:45:515 | RL |     INFO  | +0     | Main - RocketLauncher received "Steam" and "Ultra Street Fighter IV"
21:46:45:531 | RL |     INFO  | +15    | Main - Did not find a "I:\RocketLauncher\Settings\Steam\Game Options.ini" file, skipping any game-specific options.
21:46:45:531 | RL |     INFO  | +0     | Main - Ultra Street Fighter IV is using the default emulator: PCLauncher
21:46:45:531 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in I:\RocketLauncher\Settings\Steam\Emulators.ini
21:46:45:531 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in I:\RocketLauncher\Settings\Global Emulators.ini
21:46:45:531 | RL |     INFO  | +0     | Main - Found [PCLauncher] in I:\RocketLauncher\Settings\Global Emulators.ini
21:46:45:531 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk exists
21:46:45:531 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
21:46:45:531 | RL |     INFO  | +0     | Main - Ultra Street Fighter IV will use module: I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ahk
21:46:45:546 | RL |     INFO  | +16    | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher".
21:46:45:546 | RL |     INFO  | +0     | Main - INI Keys read
21:46:45:546 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Module Extensions\7z.exe exists
21:46:45:546 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Module Extensions\7z.dll exists
21:46:45:546 | RL |     INFO  | +0     | Main - "Ultra Street Fighter IV" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
21:46:45:546 | RL |  WARNING  | +0     | Main - SkipChecks is enabled and set to: Rom and Emu
21:46:45:546 | RL |     INFO  | +0     | CheckPaths - Started
21:46:45:546 | RL |     INFO  | +0     | CheckPaths - Ended
21:46:45:546 | RL |     INFO  | +0     | BuildScript - User Variables:
#NoTrayIcon
#InstallKeybdHook
SendMode, Event
0 = 10
pluginExt = .plugin
contextOnExit = 1
rlMode =
rlVersion = 1.0.1.2
rlAuthor = djvj
primMonitor = 1
frontendPID =
frontendExt = exe
frontendDrive = I:
forceHoldKey = ~Esc
restoreFE = false
emuFullPath =
emuPath =
emuExt =
romPath = I:\SteamLibrary\SteamApps\common\Super Street Fighter IV - Arcade Edition
romPathFromIni = I:\SteamLibrary\SteamApps\common\Super Street Fighter IV - Arcade Edition
romExtension =
romExtensionOrig =
romExtensions =
executable =
systemDbName = Steam
systemName = Steam
dbPath =
dbName = Ultra Street Fighter IV
dbExt =
romName =
romMapPath =
altRomNameOnly =
altRomNamesOnly =
romMapScenario =
skipchecks = Rom and Emu
romMatchExt = false
blockInputTime = 0
lockLaunch = false
lockLaunchGame =
logLevel = 3
sysType = 32-bit
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdAddDrive = true
ledblinkyFullPath =
emuIdleShutdown = 0
hideCursor = false
hideEmu = false
hideFE = false
fadeIn = false
fadeInDelay = 0
fadeInExitDelay = 0
fadeOut = false
fadeOutDelay = 0
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr4Adjust = 1
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBar = 7zOnly
fadeBarBack = true
fadeBarH = 30
fadeBarR = 10
fadeBarXOffset = 0
fadeText1X = 0
fadeText1Y = 0
fadeText2X = 0
fadeText2Y = 0
fadeInterruptKey =
7zEnabled = false
7zExtractPathOrig =
7zDelTemp = true
7zSounds = true
mgEnabled = false
mgKey = ~NumpadSub
mgSidePadding = 0.2
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgCandidate =
mgOnLaunch = false
pauseZoomInKey = C
pauseZoomOutKey = V
keymapper = xpadder
CustomJoyNames =
systemProfile = I:\RocketLauncher\Profiles\xpadder\Steam
xPadderSystemProfile = I:\RocketLauncher\Profiles\xpadder\Steam\_Default
emuProfile = I:\RocketLauncher\Profiles\xpadder\Steam\PCLauncher
romProfile = I:\RocketLauncher\Profiles\xpadder\Steam\Ultra Street Fighter IV
ahkSystemProfile = I:\RocketLauncher\Profiles\AHK\Steam
ahkEmuProfile = I:\RocketLauncher\Profiles\AHK\Steam\PCLauncher
ahkRomProfile = I:\RocketLauncher\Profiles\AHK\Steam\Ultra Street Fighter IV
pressDuration = -1
emuVolume = 1
mon1O =
21:46:45:546 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
21:46:45:546 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
21:46:45:546 | RL |  WARNING  | +0     | BuildScript - "I:\RocketLauncher\Lib\User Functions Init.ahk" not found
21:46:45:546 | RL |     INFO  | +0     | BuildScript - Validating module
21:46:45:546 | RL |     INFO  | +0     | BuildScript - Validation complete
21:46:45:546 | RL |     INFO  | +0     | BuildScript - Module:
MEmu = PCLauncher
MEmuV =  N/A
MAuthor = djvj
MVersion = 2.1.6
MCRC = AEF9EDF1
iCRC = 2DC5F958
; Notes:
StartModule()
Else
missingKeys = 1
BezelGUI()
FadeInStart()
BezelStart()
If DiscImage {
appIsImage=1
} Else
CheckSettings()
If PreLaunch {
If errLevel
DxwndRun()
Else {
If mode = url
If errLevel
If PostLaunch {
If errLevel
If FadeTitle {
WinWait(FadeTitle)
If AppWaitPID = 0
If SteamIDPID = 0
} Else If AppPID {
} Else
BezelDraw()
FadeInExit()
If AppWaitExe {
} Else If AppPID {
} Else
If PostExit {
If errLevel
If appIsImage
; If AppPID = 0
If DXWndGame = true
DxwndClose()
BezelExit()
FadeOutExit()
ExitModule()
CheckSettings() {
If (SteamID) {
If !SteamID
If !SteamIDExe
Else
If preLSkip
If postLSkip
If postESkip
If mode = standard
CloseProcess:
FadeOutStart()
WinClose(FadeTitle)
Send, !{F4}
} Else {
Return
21:46:45:562 | RL |     INFO  | +15    | BuildScript - Loaded Multi-Player scripts
21:46:45:562 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
21:46:45:562 | RL |  WARNING  | +0     | BuildScript - "I:\RocketLauncher\Lib\User Functions.ahk" not found
21:46:45:562 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
21:46:45:562 | RL |     INFO  | +0     | Main - Module is built
21:46:45:562 | RL |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\AutoHotkey.dll exists
21:46:45:562 | RL |     INFO  | +0     | Main - Running module
21:46:45:703 | MD |     INFO  | +N/A   | Module initialized
21:46:45:703 | MD |     INFO  | +0     | StartModule - Started
21:46:45:703 | MD |     INFO  | +0     | StartModule - MEmu: PCLauncher
MEmuV: N/A
MAuthor: djvj
MVersion: 2.1.6
MCRC: AEF9EDF1
iCRC: 2DC5F958
MID:
21:46:45:703 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Steam"
21:46:45:703 | MD |     INFO  | +0     | PluginInit - Started
21:46:45:703 | MD |     INFO  | +0     | CheckFile - Checking if I:\Hyperspin\Databases\Steam\Steam.xml exists
21:46:45:765 | MD |     INFO  | +63    | PluginInit - Ended
21:46:45:765 | MD |     INFO  | +0     | StartModule - Ended
21:46:45:765 | MD |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Modules\PCLauncher\PCLauncher.ini exists
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - SteamID: 45760
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - Application:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - AppWaitExe:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - DiscImage:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - Parameters:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - OriginGame:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - DXWndGame:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - WorkingFolder:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PreLaunch:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PreLaunchParameters:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PreLaunchSleep:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostLaunch:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostLaunchParameters:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostLaunchSleep:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostExit:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostExitParameters:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - PostExitSleep:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - ExitMethod:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - FadeTitle:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - FadeInExitSleep:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Ultra Street Fighter IV] - BezelEnabled:
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelEnabled:
21:46:45:765 | MD |     INFO  | +0     | CheckSettings - Started
21:46:45:765 | MD |     INFO  | +0     | PCLauncher - SteamID is set, setting mode to: "steam"
21:46:45:765 | MD |     INFO  | +0     | CheckFile - Checking if I:\RocketLauncher\Modules\PCLauncher\SteamIDs.ini exists
21:46:45:765 | MD |     INFO  | +0     | Module Setting - [45760] - exe: SSFIV.exe
21:46:45:765 | MD |     INFO  | +0     | PCLauncher - Found an exe in the SteamIDs.ini for this game: "SSFIV.exe"
21:46:45:765 | MD |     INFO  | +0     | CheckSettings - Ended
21:46:45:765 | MD |     INFO  | +0     | Steam - Started
21:46:45:765 | MD |     INFO  | +0     | Steam - Received SteamID: "45760" | SteamProtocol: "" | Parameters: ""
21:46:45:765 | MD |     INFO  | +0     | GetSteamPath - Started
21:46:45:765 | MD |     INFO  | +0     | CheckFile - Checking if \ exists
21:46:47:531 | MD |    ERROR  | +1765  | ScriptError - This is a folder and must point to a file instead: \
21:46:47:531 | MD |     INFO  | +0     | ExitModule - Started
21:46:47:531 | MD |     INFO  | +0     | Starting Updating Statistics:
21:46:47:687 | MD |     INFO  | +156   | Game section statistics updated.
21:46:47:687 | MD |     INFO  | +0     | ExitModule - Ended
21:46:47:687 | MD |     INFO  | +0     | End of Module Logs
21:46:47:781 | RL |     INFO  | +2219  | Main - Module ended, exiting RocketLauncher normally
21:46:47:781 | RL |     INFO  | +0     | ExitScript - Started
21:46:47:781 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
21:46:47:781 | RL |     INFO  | +0     | ExitScript - Ended
I still cannot get rocketlauncher to launch Steam games via SteamID BUT after hours and hours of tinkering I figured out an alternate way to launch steam games and pretty much anything else, lnk, urls, etc (files that rocketlauncher wouldnt typically let you set as executable.)
I'm not good with coding of any kind (if you can even call this that) so this was a big deal to me haha. Heres how I did it:
Right click on Steam game desktop shortcut
Select and copy the game id within url i.e. steam://rungameid/228400
Create a new text document
Enter the following within the txt document: "start steam://rungameid/228400" (Change the ID # to match yours)
Save the document and close it
Change the file extension to '.bat' and save
Configure your pc games like you normally do except instead of entering a steamID or the traditional executable, select the .bat file we just created.
You will also need to set FadeTitle in the traditional way.
Using this method I can launch all steam games because it is initiated in a traditional (mostly) manor. Steam trys to work against you launching games outsite of its self, so by using this bat we are effectively just clicking a desktop link without the clutter.
It wasn't clear but I was asking a question if you had set pclauncher as a virtual emulator and you should not add a ROM path.
If you find out want the problem was let us know.
Will do, I don't want to see anyone else go through that haha. I followed you're tutorial (Giga Guides right?) I could upload my rocketlaunch folder if that would let you get a better look. Either way if I ever figure it out I will post.
I did see your message on the channel but I can't reply to it directly. What I haven't asked is which version of HyperSpin are you using? If you're on 1.3.3. then did you run the transition tool after adding the system.
V1.4
I am having the same problem bringing my steam games to hyper spin
 Try my trick, I got all my games up and going now.
http://www.hyperspin-fe.com/topic/11059-launching-steam-games-fails/#entry167218
